Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    ROG Member Array
    Nov 2014
    22
    g751 jt left usb problem
    when i start up the laptop i will almoust everytime have to pull out my mice (katana) and put it back in to be found by the laptop.
    Its working fine until i shut the laptop of and on again.
    Im using win 8.1 and cant find any conflicts on my usb ports.
    ROG Enthusiast Array
    Aug 2014
    28
    Try Advanced Power Options > USB Settings > USB selective suspend setting and choose disabled. I believe I had this same issues and this solved it. Is it the left USB closest to the palm rest or screen?
    ROG Member Array
    Nov 2014
    22
    I have that setting to disabled but it keeps happening, any other solution? Its the usb closest to screen that im having the problem wiht, the other one works fine
    thx for reply
    New ROGer Array
    Feb 2014
    2
    Quote Originally Posted by Carl Fredrik View Post
    I have same problem , update bios 205 can't fix my problem " pull out my mice and put it back many times "
    ROG Member Array
    Jan 2015
    5
    Unhappy
    I have the same problem. Did you manage to get by this ?
    OS: 8.1
    BIOS: 205
    Oct 2014
    62
    Hello,
    Please see my solution Click Here Post #364, Hope this helps you
  7. #7
    ROG Member Array
    Jan 2015
    5
    Hi dapogz , unfortunately id did not make a difference. If connect a HDD or memory stick to one of the two ports, it works as expected but when I insert another HDD or stick into the second port the speed drops or halts or even freezes my laptop. So adding more power drain to that PCIX lane kills it.
  8. #8
    Banned Array
    Mar 2014
    185
    Quote Originally Posted by dao_s33k3r View Post
    Welcome to the world of ASUS USB 3.0 problems since the G75VW and still ongoing! their engineers cannot produce a quality laptop that just works, plain and simple
  9. #9
    Oct 2014
    62
    Hello,
    Are you running on battery? sometimes when i connect my very old 80gb seagate on the USB on the left.(on battery) it slows or sometimes disconnects because the power on the left USB side cant support the hardrive needed power when on battery.. but when plug in it works fine.. dont knoew the real problem but it makes me think that, the left USB is maybe short on voltage. because the right USB has a powerplug which outputs more voltage and still output current even on off (i can still charge my phone - using it as powerbank )
  10. #10
    ROG Member Array
    Jan 2015
    5
    @pokerface Well if this goes on since G75VW then it's a matter of stupidity in my opinion. It's one thing to discover the problem after launching and another to have the same problem to multiple generations and not fix it.
    @dapogz They are new SATA 3 disks but the same thing happens no matter what I connect to those ports IE a laptop cooler and a memory stick or two memory sticks.
