Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    ROG Enthusiast Array
    Nov 2014
    53
    I have the same issue now with a keyboard. Keeps disconnecting and reconnecting mid-game.
    I have however disabled the power management options for all hubs in the device manager... still nothing.
  2. #12
    Banned Array
    Mar 2014
    185
    Quote Originally Posted by rogdood View Post
    yeah that's why I returned mine, all the latest ASUS laptops from the G750JX onwards have an issue with the left USB ports. ASUS doesn't know how to produce a motherboard with all USB ports working fine.
    Read my thread why I returned my G751JY:
    http://rog.asus.com/forum/showthread...my-ASUS-G751JY
  3. #13
    Nov 2014
    53
    Yea, strange thing is, this issue manifested itself on the right side as well. And only with the keyboard, eveything else seems to run just fine. I have 2 external HHDs connected on the left side everyday, but I'm on a trip and I took only an external keyboard and mouse. Mouse is ok, keyboard disconnects randomly no matter what USB port it is connected into.
  4. #14
    ROG Guru: Platinum Belt Array hmscott PC Specs
    hmscott PC Specs
    Laptop (Model)Asus G750JH-DB71 (legacy)
    MotherboardAsus G750JH Intel HM87
    ProcessorIntel i7-4700HQ XTU Cores 36x/35x/34x/34x Cache 36x -50mV undervolt
    Memory (part number)Hyundai Electronics HMT41GS6AFR8A-PB 1.35v DDR3L-1600MHz
    Graphics Card #1Nvidia 780m Asus GPU Tweak OC 932mhz/6300mhz
    Sound CardRealtek v6.0.1.7469 driver
    MonitorAUO B173HW02 V1 Custom Refresh 85hz
    Storage #1RAID0 2x M.2 SATA Crucial MX200 512GB CT500MX200SSD6
    Storage #2Crucial 512GB 2.5" MX200 CT500MX200SSD1
    Power Supply230w AC Power Adapter 19.5v
    Keyboard Logitech k400 Wireless KB/Trackpad
    Headset Sony MDR-XB500 Wired and Sennheiser RS-220 Wireless TOSLINK
    OS Windows 8.1 + 8 Linux VM's + Windows 10 Technical Preview
    Network RouterAsus RT-AC68U DLINK DIR-655
    Jun 2013
    44
    5,357
    rogdood, the power management disable is only for disconnects with external disk enclosure controllers that don't play nice with Intel USB 3.0 power management. It won't help with keyboards/mice/etc.
    If you have devices that are incompatible with the left side ports, use them on the right side. If you need more ports, use a powered Hub - on either side.
    Asus might have used a different / additional controllers for USB 3.0 and/or included some USB 2.0 ports to be compatible with more USB devices, but went with all Intel HM87 fast USB 3.0 ports.
    Asus isn't the only laptop with USB issues, it is a controller issue, Asus doesn't make the controllers - Intel makes the one used in the G750/G751.
    There are Asus motherboards with multiple controllers - to avoid these incompatibilities, but Asus chose to use the newest /fastest interface to the CPU for the G750/G751. Unfortunately not all USB devices are compatible.
    Why give up on a laptop because of USB incompatibilities? - get new USB devices, use the old ones on old computers.
    If you must have the disk / data on the G571 - get a new USB 3.0 enclosure that is compatible and move the data/disk to it. That's what I did when USB 3.0 came out and there were so many incompatibilities then - this isn't a new issue
  5. #15
    Banned Array
    Mar 2014
    185
    Quote Originally Posted by hmscott View Post
    Asus might have included some USB 2.0 ports to be compatible with more USB devices, but went with all fast USB 3.0 ports.
    hmscott, with all do respect, I do not agree.
    If you are saying this is an Intel controller's fault and ASUS chose to use all USB 3.0 ports rather than keep 2 USB 2.0 devices for compatibility reasons.........then why is it that on my Alienware 18 which also has all USB 3.0 ports all USB devices work fine on all ports?
  6. #16
    hmscott PC Specs
    Jun 2013
    44
    5,357
    Quote Originally Posted by pokerface View Post
    What are the chipset(s) for your USB 3.0 controller(s) on your Alienware 18" laptop? If they are different than the ones used on the G750/G751, then the compatibility profile will be different.
    If I got a new laptop, and a USB device(s) didn't work, I wouldn't get rid of the laptop, I would find compatible USB devices.
    All of my USB devices work on my G750JH (and also worked on my JW/JX), the same USB controllers as the G751. So I know it can happen, I am using it every day.
    I have a WD 2TB USB 3.0 drive connected on the left side, bus powered, along with a USB wireless dongle to support my wireless keyboard. On the right side I have a 1TB USB 3.0 and my phone/tablet sync port. No disconnects, and no transfer issues.
    Updated for clarity:
    "Asus might have used a different / additional controllers for USB 3.0 and/or included some USB 2.0 ports to be compatible with more USB devices, but went with all Intel HM87 fast USB 3.0 ports."
    Different incompatibilities for different laptops. Migrate to what works on your laptop. Change is good
  7. #17
    Banned Array
    Mar 2014
    185
    all I know is my Alienware uses the HM87 chipset which is the same as the one in the G751JY
  8. #18
    hmscott PC Specs
    Jun 2013
    44
    5,357
    pokerface, you can check using a hardware inventory program like hwinfo64, in the G750 it is a Lynx Point PCH USB 3.0 / USB 2.0 (not used) only
Name:	hwinfo64 lynx usb 3.0 controller.JPG
    Many Alienware laptops have used the Renesas Electronics USB 3.0 Host Controller, like the M18x.
    What shows up in hwinfo64 in your AW 18", only the Intel Lynx Point interface(s), or?
