Page 15 of 27 FirstFirst ... 5 13 14 15 16 17 25 ... LastLast
Results 141 to 150 of 263
  1. #141
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    Well yes Intel never wrote or Published USB 3.0 drivers for window 8 or 8.1 or 10. If your running windows 7 the Intel drivers work perfectly
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
  2. #142
    New ROGer Array
    Jun 2015
    2
    Is this seriously still an issue? G751's left side USB 3.0 can only run at USB 2.0? The USB 3.0 standard was released 7 years ago.
    ASUS: this has been going on for many years, and it's an issue that's also present in your other products, like your motherboards (e.g. P8Z68). I'm in the process of choosing a gaming laptop and have all but decided to go with MSI. Just registered to voice my disappointment in how you're treating your existing customers.
  3. #143
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    Well yes for some people. Most people don't have the issue while many still do. Some have been RMA and had the daughter card either replaced or correctly connected.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
  4. #144
    ROG Guru: Yellow Belt Array
    Dec 2014
    12
    201
    People that don't have the issue didn't use an external HDD. The problem shows up there all the time
  5. #145
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    Yea I solve it by using the right port with a right angle adapter and 4 port hub. No problems just use left ports for USB 2.0 devices
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
  6. #146
    Banned Array
    Aug 2014
    178
    So everyone have the problem or just me? I sending it to Asus For RMA for many time already.
    The problem i face was BLackscreen and USB port ( left side)
    Why so hard to fix this? hope they replace a new G751 for me with G-sync
    btw, I'm super hardcore asus fan, invested more than 7000USD in all its toys at all time. when coming to notebook, G751 has the most problem at all time.
  7. #147
    ROG Guru: Orange Belt Array AQUASTEVAE PC Specs
    AQUASTEVAE PC Specs
    MotherboardROG Crosshair VI EXTREME
    ProcessorRyzen 7 1700
    Memory (part number)32gb GSkill FlareX 3200mhzC14
    Graphics Card #1GIGABYTE 1080 ti EXTREME
    Monitor55" UHDR 4K TV
    Storage #1SAMSUNG 960 EVO M.2 NVME 500GB
    Storage #2SAMSUNG 951 M.2 PCIe AHCI 512GB
    CPU CoolerNZXT kRAKEN X62
    CaseCOOLERMASTER MAKER 5T
    Power SupplyCORSAIR RM850X
    Keyboard LOGITECH K850 WIRELESS BACKLIT
    Mouse LOGITECH M570 TRACKBALL WIRELESS
    Headset 2.4GHz Wireless Headphones with Detachable Mic and Rechargeable Battery
    Mouse Pad LOLOLOLOLOLOL....
    Headset/Speakers VIZIO SOUND BAR, SUBWOOFER AND SURROUND SPEAKERS
    OS WIN 10 PRO
    AQUASTEVAE's Avatar
    Nov 2011
    11
    374
    Quote Originally Posted by hexaae View Post
    Be sure you have Microsoft drivers installed, not Intel crappy ones...
    I had some problems with a radio controlled mouse connected to the 2nd port from top on the left side, when I attached also a USB 3.0 external SSD. This with the Intel drivers (mouse was often unresponsive and "wobbling" as if there was insufficient power). Then Uninstalled and deleted the Intel ones and installed those by MS searching in my computer. The problem seems gone and ports are now reliable (I have BIOS 207).
    My supposition is that Intel drivers supply not enough power to optimize power consumption causing this issue.
    EDIT: doh.. the problem JUST reappeared at least once.
    i haven't had any problems with my usb 3.0 ports on either side. but when i looked at the pic you provided, and then looked at my own in dm, i noticed a difference between mine and yours, you don't seem to have the usb 3.0 host controller extensible. check out my inserted pic.Click image for larger version.
    CoolerMaster Maker 5T - ASUS CROSSHAIR VI EXTREME - 55-inch UHD 4k Display - AMD Ryzen 7 1700 - NZXT Kraken X62 - 7 CoolerMaster/NZXT RGB Case Fans W/ HUE+ - Gigabyte AORUS 1080 TI EXTREME - 32GB GSkill FlareX 3200Mhz DDR4 - Samsung 960 EVO M.2 NVMe 500GB - Samsung 951 M.2 AHCI 512GB - Samsung EVO 840 1TB SSD - Crucial MX100 SATA 3 500GB SSD - WD BLUE 8TB HDD - Logitech K350 wireless wave keyboard - Logitech M570 wireless trackball - Dual booting WIN 10 Pro Fall Creators Edition
  8. #148
    ROG Guru: White Belt Array
    Mar 2013
    90
    What driver version is that?
    Mine is:
  9. #149
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    Well many don't have the issue, many do have the issue myself included. I have worked around it. The issue is power related as has to do with the left port being Daughter board if the connections to mother board is not perfect you will have disconnect issues with USB 3.0 devices. USB 2.0 Devices have no issues on the left ports.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
  10. #150
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    Yes this new USB 3.0 Driver must have recently been downloaded and installed my computer is showing the same. It looks to me like the poster is trying to use the windows 7 USB 3.0 driver from Intel. Don't think it works and Intel is not going to distribute and new one since its standard and MS has put it native in window 8 and up.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
