Results 1 to 4 of 4
    New ROGer Array
    Nov 2014
    1
    Can not get past 60hz with SLI GTX 980S
    Hi there just built a new pc with this monitor in mind and when I hit the turbo button it will not go past 60hz, I am using displayport mini (StarTech.com Mini DisplayPort to DisplayPort Adapter Cable - Video/Audio Cable - Mini-DisplayPort (M) - 20 pin DisplayPort (M) - 1.8 m - Latched) That cable should display 4k. Any help would be great.
    Helium Chilled Array _ PC Specs
    _ PC Specs
    Laptop (Model)G46VW
    MotherboardRampage IV Gene
    ProcessorIntel Core i7-3930K
    Memory (part number)Corsair Dominator Platinum 32GB (CMD32GX3M4A2133C9)
    Graphics Card #1ROG Matrix GTX 780 Ti
    Sound CardROG SupremeFX III
    MonitorASUS VG248QE with GSync mod
    Storage #1Plextor PX-M2 SSD 120GB
    Storage #2G.Skill Phoenix Blade 480GB PCIe SSD
    CPU CoolerCooler Master Seidon 240M
    CaseCooler Master HAF-X
    Power SupplySeasonic X-750
    Keyboard Corsair K90
    Mouse ROG Gladius
    Headset ROG Orion
    OS Windows 8.1 Update 1
    Network RouterASUS RT-AC66U
    _'s Avatar
    Dec 2011
    119
    5,750
    You need to keep the mouse moving or it needs to be in game for the Turbo button to activate. A static display won't change.
    It's also possible that your adapter is stopping it (and possibly GSync).
    ROG Enthusiast Array Astrix_au PC Specs
    Astrix_au PC Specs
    MotherboardASUS Maximus VI Formula
    Processori7 4770K @4.5Ghz
    Memory (part number)Kingston HyperX 16GB 1600Mhz (2x 8GB)
    Graphics Card #1MSI R9 Fury X 4GB HBM
    MonitorBenq XL2730Z 2550x1440p 144hz 1ms Freesync
    Storage #1Samsung 840 EVO SSD 500GB (OS)
    Storage #2Samsung 840 EVO SSD 200GB
    CPU CoolerCorsair H80i
    CaseCorsair 750D Air
    Power SupplySeasonic 1000w 80 Plus Platnum
    Keyboard Roccat Suora
    Mouse Razer Mamba 2012
    Headset Astro A50 Headset
    OS Windows 10 64bit
    Network RouterNetgear CG3000
    Accessory #1 TrackIr 5
    Accessory #2 Thrustmaster T.16000M
    Accessory #3 Thrusmaster TWCS Throttle
    Astrix_au's Avatar
    Nov 2013
    54
    What about the original cable? Does it reach 144hz? Try changing it through windows Screen resolution settings.
    ASUS Maximus VI Formula - i7 4770K - H80i - MSI R9 Fury X - HyperX 16GB Ram - 250GB + 500GB Samsung 840 EVO SSD - Benq XL2730Z 2560x1440p 144hz Freesync - Seasonic 1000w 80 Plus Platnum...
    _ PC Specs
    Laptop (Model)G46VW
    Mouse ROG Gladius
    Headset ROG Orion
    _'s Avatar
    Dec 2011
    119
    5,750
    The cable shouldn't be the issue unless it's damaged, but that's more of a it works or it doesn't.
