MacHinery wrote:
Low level viruses that prevent basic functionality won't nesc. Be resolved by a factory reset unless they are programmed to go dormant. HAve you done a factory reset? If so, has it worked?
Hello,
Thanks for the response. While I was troubleshooting, I made laptop to start by somehow, while laptop was on, I noticed that it shows charging then battery so it seems to be an issue with the power jack or cable, recently I bought a new AC Adapter and Battery they were working fine for few months, I think the issue might be power jack, I already ordered one and will replace, my doubt is why Laptop will power on and stay screen off, does not seems to be related to the power jack issue...
Thanks
