Results 1 to 8 of 8
    ROG Guru: White Belt Array
    Nov 2014
    91
    g751 sound settings
    Hello when i play on the highest volume on spotify and on windows i get a vibrating sound from my left mouse button on the laptop, now my question is, is it normal that high sound can make laptops make vibrating sound? should i return it for this? also please post your settings so i can use them might make the sound better, it even does it when i plug in my usb and that usb sound comes up
    Nov 2014
    91
    Anyone?
    ROG Enthusiast Array
    Oct 2014
    27
    Go to control panel -- Audio Wizard, Change the setting from Multimedia to off. Does this make your sound better?
    Nov 2014
    91
    Nope makes it worse the vibration that is. It comes from the mouse pointer on the keypad
    New ROGer Array
    Dec 2014
    2
    Ya i am experiencing the same thing. probably part of the chassis. A recommendation is to go into sound settings and lower the top of the "front". this will reduce the max volume output, but will reduce the vibration at the max volume.
    ROG Member Array
    Nov 2014
    7
    You probably have same creaking sound problem we all are facing. Change audio quality in Realtek Audio manager to highest and keep a close eye on the Imbalanced sound thread.
  7. #7
    Dec 2014
    40
    Im also having the same issue i. i found the main issue to be from the 300-500 hz range. in the audio wizard when your on speakers turn doen those frequencies and it should help some
  8. #8
    Dec 2014
    86
    Quote Originally Posted by BullFinch View Post
    Having the same issue with the same laptop I have bought today, a bit of a difference with your suggestion thank you!
    Also does anybody know how to get the rog wallpaper like most are shown with on youtube?
