Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    ROG Member Array
    Nov 2014
    ROG G750 JW -LOL fps problem when unplugged / using battery power
    So i just got the ROG G750 JW and gforce experience sets the setting on very high for every thing on my laptop (for lol)
    so when its plugged in i get 200 fps ( not sure if true ) with not even a stutter,
    but when its plugged out i get 30-50ish fps and it lags (on battery).
    Any idea why, please help.
    ROG Member Array
    Nov 2014
    sorry double post D:
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,651
    You cannot game properly on battery, the G750's dedicated card doesn't allow it.. not smoothly.
    ROG Member Array
    Nov 2014
    Quote Originally Posted by Darnassus View Post
    is there any way to fix that or bypass that ?
    also is it in this model or every other model ?
    further more i was playing dmc4 and got 15~~ fps on battery... that is just sad..
    thanks...
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,651
    Not that I'm aware of, but if you did, the battery would only last around 40 minutes to 50 and would strain it severely.
    The GPU is dedicated, not integrated. It has it's own components and everything it needs that a GPU would normally, thus requires a lot of power.
    If you look at your charging brick, you'll find that it supplies 20volts and 10amps, I have a good feeling a lot of that power from the brick goes to the GPU directly. (Theoretically anyway).
    With the first generation G750's, the internal graphics (Inside the 4700) is completely ignored. If you wanted that, (which probably wouldn't run the games anyway) you would have needed to buy the second gen or above, being the G750JM / JS / JZ
    ROG Member Array
    Nov 2014
    any suggestion what i should do ?
  7. #7
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,651
    Well.. game while plugged in. It's the best thing you can do. ':x
  8. #8
    ROG Member Array
    Nov 2014
    then calling it a laptop is futile... if i cant game on the go.... hell i can even play DMC 4 with out lag....damn it.
    disappointed.
  9. #9
    ROG Member Array
    Mar 2013
    11
    You need to go to the NVidia GeForce Experience, search for Battery Boost and set it properly/disable it. Your choice.
    P.S. I see that ROG Guru here are pretty disinformed, what a shame...
  10. #10
    ROG Guru: Green Belt Array Maxter's Avatar
    Aug 2013
    13
    598
    lower the graphics to low-medium, then you can play on battery.... gives you 1.5 hours (2 games)
