Results 1 to 7 of 7
    ROG Member Array
    Sep 2013
    20
    Rampage V Extreme Fresh build will not turn on
    Howdy all, Just wondering if i can get some advice on a situation that is happening.
    Just finished putting together this new system for a friend and went to boot it up to install windows on it.
    Specs:
    V Extreme
    Dominator 15gb DDR4
    EVGA video
    Corsiar closed loop water cooler
    1200AXI PSU
    What's happening is when it is turned on, lights and fans all light up, It posted once, something about CPU fan not there. Which i then re pluged the power from the water cooler unit into the CPU fan power and tired again.
    It now power's on, wait's for a few moments and then power's down with nothing appearing on the screen.
    Please some advice would be welcome
    ROG Member Array
    Sep 2013
    20
    After a bios reset via the back button, i was able to start the windows installation. During which when it want's to reset the PC multiple times it would not auto restart, and has now gone back to doing the same thing, powering on then off
    ROG Member Array
    Sep 2013
    20
    Now its giving code 6F saying overclock is incorrect when i haven't touched a single thing on the OC settings
    ROG Member Array
    Sep 2013
    20
    I7 5960x
    Corsair AX1200i
    EVGA GeForce GTX 970
    Corsair Dominator Platnum 16gb (4x4)
    Rampage V Extreme
    Corsair Hydro H105
    WD Red 2TB X2
    ROG Guru: Brown Belt Array abvolt's Avatar
    Aug 2013
    41
    1,131
    are all power connectors on the board plugged in, the 8 & 4 pin..
    Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
    NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
    Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
    Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
  7. #7
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Disconnect your hard drives. Then clear CMOS.
    Are you getting any video output on your screen now?
