ariskar wrote:
R5E + Sound card + M2 + GPU = PCIe allocation mess
I think this is basically correct.
Plugging the sound card into the x8_2 (PCIe 2.0) slot interfaces it to the chipset PCH, less inter-device polling clutter distracting the processor PCIe 3.0 controller. As long as the PCH-to-processor DMI 2.0 bandwidth isn't saturated (by SATA devices, USB devices, etc) the sound card will function just as well (or better) than it would on a crowded PCIe 3.0 bus - while incidentally no longer interfering with operation of the GPU(s), maybe you get +1fps lol!
I doubt a firmware update can do much, the mobo slot configuration is hardwired into the R5E design, along with add-on implementations of device/interface support for M.2, SATA Express, more USB 3.0 ports, etc.
saracg wrote:
SBZ was on x4_1 slot (gray one). when i changed the slot to x8_2 the problem gone.
Any ideas? i really would prefer x4_1 since soundcard is blocking air of the GPU at the moment compared to its previous position.
You can steal a little server technology here: various kinds of
PCIe slot risers/adapters/extenders can use the electrical connection at one slot while mounting the card at a different physical location (such as in an unused chassis backplate slot beyond the bottom edge of the mobo). Cable management might be a little challenging when other slots need to remain populated/reserved, but it's still an option for possible improvement. You can even mod an entirely non-standard internal placement for your sound card (bolt it into a drive bay or whatever) and bring the connectors out through conventional ports. Incidentally, the capacitors you see on some of these products are meant to compensate for the increased impedance of the longer signalling runs (which are technically disallowed by official
PCI-SIG standard specifications), they can reduce critical timing/latency problems which wouldn't be much of an issue on a device like a sound card anyways. (But don't blame me if your sound card makes strange whirring noises when your drives spin up!)
maartieboy wrote:
I also get a static noise every now and then.
I'm using the 5820k and 2x gtx 980
The manual says that PCIE_X8_4 is disabled for 28 lane cpu's. Does this mean I can't even plug my soundblast z into that slot to fix it?
The 5920K will only support up to x16/x8 or x8/x8/x8 SLI. And the R5E deactivates the PCIE_X8_4 slot entirely - but this actually seems like an arbitrary limitation and is perhaps something which might be corrected through a future firmware update. Plug sound card into PCIE_X4_1 slot, upgrade processor, or use a different X99 mobo, sorry.
[/Korth]
