Results 1 to 2 of 2
    New ROGer Array
    Dec 2014
    2
    G750JZ - Displayport hub for 3 x VGA projectors?????
    Has anyone used displayport hub for 3 external monitors/projectors with G750JZ?
    I'm working with video installations for exhibitions and theatre. Most usual setup is 3 x XGA VGA projectors. I could get Matrox Tripplehead2go Digital edition, but I'd like to have more future proof and, if possible, cheaper solution.
    I'm looking into something like this, as they specifically state that VGA adapters should work: http://www.startech.com/AV/Displaypo...ub~MSTMDP123DP
    Can anyone think of a reason why the setup shouldn't work?
    New ROGer Array
    Dec 2014
    2
    Lets generalize the question... Has anyone used any Displayport hub with any Asus Rog G750 series laptop?
Tags for this Thread
