Results 1 to 4 of 4
12-16-2014 05:03 AM #1
- Join Date
- Nov 2014
- Reputation
- 10
- Posts
- 7
Battery Charging light went kaput, not sure if this is normal.
As the title says, my CH71's battery charging light went out suddenly. See the attachment. For some reason this laptop is now frustrating me. Do let me know if there is any fix for this. Also rest of the panel lights are not working properly as well. This when charge is 97% and ac is on.
12-17-2014 12:59 AM #2
- Join Date
- Nov 2014
- Reputation
- 10
- Posts
- 7
Interestingly, if you press just about right above the numlock indicator it goes off and if you press a little bit more the airplane mode indicator goes off as well.
12-17-2014 02:00 PM #3
hmscott PC Specs Laptop (Model) Asus G750JH-DB71 (legacy) Motherboard Asus G750JH Intel HM87 Processor Intel i7-4700HQ XTU Cores 36x/35x/34x/34x Cache 36x -50mV undervolt Memory (part number) Hyundai Electronics HMT41GS6AFR8A-PB 1.35v DDR3L-1600MHz Graphics Card #1 Nvidia 780m Asus GPU Tweak OC 932mhz/6300mhz Sound Card Realtek v6.0.1.7469 driver Monitor AUO B173HW02 V1 Custom Refresh 85hz Storage #1 RAID0 2x M.2 SATA Crucial MX200 512GB CT500MX200SSD6 Storage #2 Crucial 512GB 2.5" MX200 CT500MX200SSD1 Power Supply 230w AC Power Adapter 19.5v Keyboard Logitech k400 Wireless KB/Trackpad Headset Sony MDR-XB500 Wired and Sennheiser RS-220 Wireless TOSLINK OS Windows 8.1 + 8 Linux VM's + Windows 10 Technical Preview Network Router Asus RT-AC68U DLINK DIR-655
- Join Date
- Jun 2013
- Reputation
- 44
- Posts
- 5,357
BullFinch, sounds like a pinched wire, it's a fault you can't fix so either return to the seller for a new one if you are still in the seller's return period, or if not then RMA to Asus for repair.
Make a list of all the things you want fixed before contacting Asus, and list everything in the RMA request first time - it's iffy to add things later.
https://vip.asus.com <== create a login, register your laptop, file a Technical Inquiry with clear details stating the problem(s) and request a repair RMA - attach a zipfile of photo's as well to help illustrate your point.
Please come back and let us know how it works out
12-18-2014 10:16 PM #4
- Join Date
- Nov 2014
- Reputation
- 10
- Posts
- 7
Thanks a lot for the reply.
I am still in the return time frame from amazon so I have asked for a replacement. Lets see how it goes.
