Corsair Vengeance pro Watercoolig?
jarokamaro007
Hi. Is there someone who has those memories and have them watercooled?If Yes wchich universal waterblock is good?
21 REPLIES 21
Nate152
jarokamaro007
Hi.4 sticks
jarokamaro007
Nate152
Yeah you can use those too. You will have a lot more tubing to play with and you will need flexible no kink tubing if you use them.
jarokamaro007
ok.Thanks For advice 😉
Nate152
And What is the story wit SPD and Tested Latency?my SPD Latency is 9-9-9-24 and Tested is 11-11-11-27.....can i change them for 9-9-9-24?will they work fine?do i have to change voltages?
jarokamaro007
Ok I will.Have question for U.I bought vengeance pro 32Gb 2133Mhz but i cant get them working at 2133Mhz.i overclocked my FX-8350 to 4.7 and max that i could set my memorry was 1920Mhz...why is that?do U know?
