Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
Thread: G53sw fan
    ROG Enthusiast Array
    Oct 2011
    66
    G53sw fan
    If you put your ear up to the left side of the laptop the fan is running very loud. It sounds sort of like a card in a bike tire, just not quite as loud. What could be wrong? I bought this about 3 weeks ago.
    The GPU has also been running 5-10 degrees hotter and the turbo boost gadget on the desktop has been jumping around a lot. Even when nothing is open and it's just sitting idle on the desktop.
    G53SW-XN1
    Intel Core i7 2630QM
    GeForce GTX 460M
    6 GB RAM
    Windows 7 Home Premium 64bit
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    28
    2,224
    There my actually be something rubbing against the fan. Look here - http://forum.notebookreview.com/asus...ns-photos.html
    I don't know why your gpu is hotter, but things running in the background will make the Turbo monitor jump around. Perfectly normal.
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
    Oct 2011
    66
    It doesn't sound like something is rubbing. I know that sound lol
    I guess I explained it wrong. It's a weird sound and hard to explain. Maybe a clicking noise?
    It's good to hear that the turbo jumping is normal though. As for the temperatures, it was idling around 42 degrees the first few weeks and the last few days it has been between 48-50. Know of any reason why or if this is a bad thing?
    G53SW-XN1
    GeForce GTX 460M
    6 GB RAM
    Aug 2011
    28
    2,224
    You may have too much bloat running in the background though. If you haven't uninstalled any of the Asus apps yet, you may want to reappraise that decision. Lol. I only kept 4. Lol
    Your gpu is hotter at idle?
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    Oct 2011
    66
    I unistalled all of the ASUS software besides the Power4Gear and the fast boot. Maybe like 1 or 2 others tops.
    And yes, it is running a little hotter idle. About 6-8 degrees.
    G53SW-XN1
    GeForce GTX 460M
    6 GB RAM
    Aug 2011
    28
    2,224
    Your house isn't warmer too, is it?
    That increase doesn't seem normal. Your heatsink may be a little loose or the paste job may be ineffective. Or maybe the fan has a problem.
    Can you bring that in for an exchange at your retailer?
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
  7. #7
    Oct 2011
    66
    I got it at Newegg and it hasn't been 30 days so I could RMA. I would rather not though. If it is the heatsink or something wouldn't it just keep getting hotter? It's is just always at 48-50 instead of 42-43. It doesn't ever fluctuate or anything. It's also always about 30 degrees right after I turn it on and it still is. So I don't think it is my house.
    G53SW-XN1
    GeForce GTX 460M
    6 GB RAM
  8. #8
    Aug 2011
    28
    2,224
    I would get that exchange. RMA means you send it to the manufacturer and they fix it and you REALLY don't want to do that.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
  9. #9
    Oct 2011
    66
    So if I send it back to Newegg and they will exchange it? How do I go about that? You really think it is absolutely necessary to get an exchange?
    G53SW-XN1
    GeForce GTX 460M
    6 GB RAM
  10. #10
    Aug 2011
    28
    2,224
    Well, its hotter for no reason. And its making a noise. It has to be fixed either by you or by Asus. And Asus RMA is like "a box of chocolates"; you never know what you're gonna get. So yes I would exchange it.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
Similar Threads
  1. G53SW vs G53SX
    By callmekart in forum ROG Gaming Notebooks
    Last Post: 09-05-2011, 03:21 AM
  2. New G53sw problems
    By fawkez in forum ROG Gaming Notebooks
    Last Post: 08-29-2011, 08:55 PM
  3. G53sw which bios?
    By azif in forum ROG Gaming Notebooks
    Last Post: 08-13-2011, 03:20 PM
  4. New Owner of a G53SW-Xn1
    By Whatsdafus in forum ROG Gaming Notebooks
    Last Post: 05-29-2011, 11:16 PM
