Results 1 to 2 of 2
    New ROGer Array
    Dec 2014
    1
    G75vw harddisk issues
    I have a g75vw with windows 7 that the hard drive went out on and just got a hp envy with Windows 8 but am locked out via password. I put the hard drive from the hp into the asus and it loads to the login screen fine but when I try to recover and install with my asus windows 7 disk it says theres no fixed drive found. It seems to reconize it in bios so is there something I could be doing wrong or is there a way to get past the windows 8 password?
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    Not sure is you can hack the password for the hard driver, get a new SSD and clean install win 7 or 8. I if that drive is password protected you would have e to hack the password that is not what we do in these forums.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
