12-24-2014 06:50 AM - last edited on 03-06-2024 02:58 AM by ROGBot
12-24-2014 07:20 AM
xyz_cityhunter wrote:
I've just ordered a G751JT and it seems like the wireless adapter given is Atheros AR956X. Don't think it's the Killer Wireless-N/AC so would like to ask if there's anyone else that is using the same wireless module? Would like to know if it's good enough for gaming or I should get something else to replace it? :cool:
12-24-2014 06:13 PM
hmscott wrote:
G750JM Qualcomm Killer Wirelsss -N issue
http://rog.asus.com/forum/showthread.php?54653-G750JM-Qualcomm-Killer-Wirelsss-N-issue&p=458463&view...
Here are the details from the post, but check out the other comments as well in that thread.
"Your AR956x is a single band, 2.4Ghz card that will do 150mbps. Here is the spec pdf, and an excerpt from that document:
https://qca.qualcomm.com/wp-content/uploads/2013/11/AR9285.pdf
Solution Highlights
Supports up to 150 Mbps
Highly integrated single chip PCI Express CMOS solution with
MAC/baseband processor and 2.4 GHz radio
Backward-compatible to 802.11g; forward–compatible to
multi-stream 802.11n
Supports all mandatory IEEE 802.11n features – including several
IEEE 802.11n optional features such as HT40, half-guard internal
in HT40 and Rx Space Time Block Coding
Compliant with IEEE 802.11b, 802.11d, 802.11e, 802.11g standards and 802.11i
150mbps is likely fast enough to handle your internet connection at full speed, but if you want to get 5ghz coverage and more throughput, buy a USB Wireless adapter like a USB 3.0 device listed here (scroll down):
http://www.asus.com/Networking/Wireless_Adapters_Products/
That is what I did when I got my G750JW, the entry level model of that range (JW/JX/JH), and it works nicely. Just don't forget to pull it out of the USB socket before putting your G750JM into your backpack :)"
It isn't a bad Wifi card, just a limited function one, as I say above check out the USB 3.0 adapters from Asus.
It isn't worth potentially voiding the warranty by damaging something internal while trying to disassemble to replace the internal Wifi card.
12-29-2014 11:41 PM
12-30-2014 03:50 AM
xamoel wrote:
The 751JY should be an AC wirelss?!
12-30-2014 09:11 PM
x7007 wrote:
Thank god I got Intel DUal Band Wireless-AC7260 xD
05-16-2015 08:41 AM
05-16-2015 04:43 PM
Ok, just changed my card above to Qualcomm Atheros QCNFA222, something equivalent to Killer-N 1202... Will see how it goes...:cool:
https://wikidevi.com/wiki/Qualcomm_Atheros_QCNFA222
https://wikidevi.com/wiki/Bigfoot_Networks_Killer_Wireless-N_1202
