Results 1 to 2 of 2
    ROG Enthusiast Array
    Dec 2014
    12
    38
    G751jy wireless issue?
    Hey guys, just a quick question if I may. Just got this beast and so far loving it. Have the sound issue, of course. But I am also encountering an issue with my wireless connection.
    have Intel ac 7260 wireless adapter and have a linksys wrt 160n with dd-wrt on it. The router has been great, no issues, ever. However when I first boot up the laptop it cannot connect to the router, I have to go into device manager and disable, and then re-enable the adapter. After that it immediately connects and works well, as far as I have been able to tell.
    Is anyone aware of a bug with the driver? Or is there a hardware issue? Thank you for your time.
    Dec 2014
    29
    Go to your router's setting and change the type of security the wireless module uses. Default is probably WPA2 with WEP enabled. Try something else like WEP or something - it should fix the issue.
