Page 1 of 19 1 2 3 11 ... LastLast
Results 1 to 10 of 189
Thread: Graphics cards
    ROG Guru: White Belt Array
    Dec 2014
    95
    Graphics cards
    ASUS NVIDIA Geforce GT630 4GB
    ASUS AMD RADEON R7 240 OC 4GB
    which one would be best for gaming??? plz help me out really con fused..............
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,358
    Hello rdx12311
    What's your budget?
    If you're going to game you're going to need something a little better than those two.
    The 240 would probably outperform the 630 after looking at the specs but the 240 has GDDR3 Vram. The 630 has GDDR5 Vram.
    The 630 supports directx 11 - 11.1 the 240 supports directx 10. If you can swing some more dollars and get something better, you'll be glad you did.
    Can you list the specs of your pc or the pc it's going in please?
    ROG Guru: Yellow Belt Array
    Dec 2014
    24
    152
    Indeed for gaming neither the GT630 nor the R7 240 are good options, just too slow for anything more than browser stuff or ancient games... and those can be handled by integrated graphics just as well.
    Dec 2014
    95
    no guys my budget is limited and I have to remain in these two graphics card .....so I have given the specs of the two cards .......please compare specs of both cards and tell me which one I should buy ?????? thanks
    1.Graphics Engine
    AMD Radeon R7 240
    2.Bus Standard
    PCI Express 3.0
    3.Video Memory
    DDR3 4GB
    4.Engine Clock
    GPU Boost Clock : 820 MHz
    GPU Base Clock : 770 MHz
    5.Memory Clock
    900 MHz ( 1800 MHz DDR3 )
    6.Memory Interface
    128-bit
    7.Resolution
    DVI Max Resolution : 1920x1200
    Digital Max Resolution:2560x1600
    8.Interface
    D-Sub Output : Yes x 1
    DVI Output : Yes x 1 (DVI-D)
    HDMI Output : Yes x 1
    HDCP Support : Yes
    9.Power Consumption
    up to 75Wno additional PCIe power required
    10Accessories
    2 x 1-slot LP Bracket
    11.Software
    ASUS GPU Tweak & Driver
    12.Dimensions
    6.26 " x 4.37 " x 0.79 " Inch
    15.9 x 11.1 x2 Centimeter
    1.Graphics Engine
    NVIDIA GeForce GT 630
    2.Bus Standard
    PCI Express 2.0
    3.Video Memory
    DDR3 4GB
    4.Engine Clock
    700 MHz
    5.CUDA Core
    96
    6.Memory Clock
    1100 MHz ( 550 MHz DDR3 )
    7.Memory Interface
    128-bit
    8.Resolution
    D-Sub Max Resolution : 2048x1536
    DVI Max Resolution : 2560x1600
    9.Interface
    DVI Output : Yes x 1 (DVI-I)
    HDCP Support : Yes
    10.Power Consumption
    11.Software
    12.ASUS Features
    Super Alloy Power
    13.Dimensions
    7.6 " x 5.12 " x 1.18 " Inch
    19.3 x 13 x2.99 Centimeter
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,358
    Thanks for the specs I looked them over, here is something you can have a look at.
    The r7 240 beats the gt630 everywhere except the memory bandwidth.
    http://gpuboss.com/gpus/Radeon-R7-240-vs-GeForce-GT-630
    Dec 2014
    95
    bro I have a query.... graphics cards with DDR5 1 GB video memory and graphics cards with DDR3 4 GB memory are they gonna give same gaming performance ....which one would be better
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,358
    I don't think I would even consider a 4GB version of those cards, I don't see them coming close to using 4GB.
    Is this in your price range?
    http://www.newegg.com/Product/Produc...-341-_-Product
  8. #8
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,358
    Scratch that here is a way better one for 59.99 after rebate.
    Can your psu handle it?
    http://www.newegg.com/Product/Produc...-793-_-Product
  9. #9
    Dec 2014
    95
    u have seen the other 2 graphics card which I provided before ...now check this one bro and tell me which one I should buy from these 3 cards.....the link I am giving you it has much higher specs than the previous 2 cards but the difference is the other 2 cards have 4GB DDR3 Memory and the last one has 1GB DDR5 memory http://www.asus.com/Graphics_Cards/GT6401GD5L/overview/
  10. #10
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,358
    Here's the thing, those 4 GB cards are going to run out of performance before the 4GB of memory is used. The higher the resolution you go the more the performance hit. The 4GB of memory will be a waste with a low end card. Check my link above, if you can afford that card and your psu can support it, get that one.
    If not go for the asus gt640.
