Corsair Vengeance Pro 32Gb 2133Mhz Timing set Up?
jarokamaro007
Hi.Just would like to ask about SPD and Tested Latency...SPD Latency is 9-9-9-24 and Tested Latency is 11-11-11-27...i seen i can change it manualy in bios...if i change from tested to SPD will they work fine?faster?do i have to change voltages or something?I overclocked my FX-8350 to 4.7 and coul not get my memorry work at more speed than 1920Mhz...Why is that?,i tought they will work at 2133 wit no problem.... 😞
3
6 REPLIES 6
Nate152
The 11-11-11-27 timings should run at 2133MHz.
Your ram kit supports X.M.P. Go into the bios on the extreme tweaker tab and set the ai overclock tuner to X.M.P. F10 and Enter. Are you able to boot?
If not you will more than likely need to bump up the vccsa voltage for 32GB.
i changed timings for 11-11-11-27 and its workin fine..i have AMD processor and there is no X.M.P opion(its only for Intel processor i think)but to get them working at 2133 i had to change my procesor frequency to standard 4Gh....what is safe overclock freqency for vengeance pro 2133?and Croshair V Formula MB and NB?cos when i overclock processor then i cant set exactly 2133 Mhz for memmory and NB and MB...now i changed Processor frequency to 4.7 and Memory to 2192Mhz..MB and NB at 2350Mhz....and im able to boot...is that setings safe?Thanks for replies 🙂
jarokamaro007
Nate152
When you raise the front side bus you raise the ram speed too. A safe overclock is determined by your temps. If your temps are under control at 4.7GHz then that is a safe overclock.
Sorry guy I can't help you with overclocking your cpu, maybe someone with a crosshair v formula board will chime in or you can start a new thread about overclocking, I'm sure someone will help you.
NemesisChild
Level 12
Manually enter your memory base timings, frequency (2133MHz), and DRAM voltage in your bios.
And you should bump up the DRAM voltage a notch or two above spec for 32GB to ensure stability.
32GB will put enormous stress on the CPU IMC, especially AMD, so you may not achieve desirable overclocking results.
Remember there is little gain by running higher memory frequencies, so if you have to down clock, then so be it.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
jarokamaro007
yesterday i set cpu clock at 4.7 and memory at 2192...MB and NB at 2350Mhz..after runing prime 95 stress test temperatures of |CPU rich- 78C ,NB- 73C, MB-41C and SB-51 is that normar results wit stress test?after that i lower down CPU clock to 4.58 memory to 2127 and NB MB to auto...and temperatures were maybe 2C lower then before...maybe better if i set up memory clock lower than i have it now?maybe lower them under 2000Mhz?
