I think you are right, hori. I have been dealing with it also. I have tested everything. The system is solid, rock solid (besides the periodic start up issue). I have also figured out a whole bunch about it. I am a programmer with a heavy IT background. Here's what I have figured out. It's a power sequence issue between the Nvida card and the system in general. For instance, (VERY IMPORTANT), the comupuer does in fact boot when our fans go to full speed, However, it is not using the Nvida card, it's using the onboard graphics output (the MB HDMI) output. I hooked up my monitor's extra HDMI connector and found that out. I did a whole bunch of R&D on the subject and found much on the nature of the card and motherboard, this was occurring in other systems when the graphics cards were not getting power or not reporting in properly to the system. With the cool fact we have the spilt (one supplies the system, one supplies the GFX card) power I ran tests (I do not suggest you repeat I don;t know the long term effects) of just powering the computer and wa-la the issue was identical, full fans boot on motherboard Intel graphics. So that proves whatever is happening is the GFX card is not either powering up or it's inital sequence is "off-timed" with the system so when the system polls it it's not in a ready state so it falls back on the onboard card. The Nvida card then shifts it's fans to full speed (perhaps it's a planned defense mechansim for a possibly overheaded card that fails to boot properly, I'm guessing it's a blind response because they rather turn the fans on full when in doubt to save the card) .
Anyway, the point is shutdown normally once it's booted to the win 8.1 login screen. then restart. Then I boot pretty much each and every time. I have been powering off and not doing the warm restart as I don't trust it. You must let the system boot, I have had disrupted the process blindly (before I knew about the secondary output was ok) with disasterous windows consequences durring my testing phases. In fact it's what lead me to try the motherboard's html output. I figured the damage I was causing to the OS by disrupting the boot mean it was booting, Thus there had to be video output somewhere.
I also have been conjecturing temperature might be a factor but I can't prove it. The GFX card may have to warm up to report in at the right time. My only evidence thus far is the issue only has occured to me when turning on the system cold and after sitting the night. But that is hardly proof.
Whatever the root cause is, my gut says it's all about timing. Asus needs to try to address this through bios/firmware updates. It might be bad enough that NVidia may need to bring out a patch for the onboard gfx card firmware.
No matter what, so far I am finding the issue manageable as long as it does not progress into something else, which I don't see happening yet. And I won't cow down to a service tech that knows less than me and go RMA on this. I know my G20 is rock solid and I refuse to go through the service maze at this time.
SO those with the issue....
Let the system boot to windows (verify with the onboard HDMI) I have my monitor cable with both my primary out and my secondary card hooked up full time now.
Do a shutdown from the windows primary login point.
Power back up.
So far that it's "manageable" we need to harp on Asus without talking to their entry level customer servcie techs, someone has to know somebody we can talk to without having to mass RMA and go through weeks/months/years of pain
