Results 1 to 10 of 10
Thread: bios problem with asus a42jy ???
11-04-2011 05:11 PM #1MATRIX.REALGuest
hi ,
i'am facing problem after bad flash bios of notebook asus a42jy and get black screen and now i cant acces to the bios...
i download original and lastest bios from asus support
formatted flash disque fat and fat32, rename file to A42JY.bin ... do all things : CTRL+HOME , FN + ESC , FN + F , windows key +B , winkey + F all but nothing happen and always same ...
i try also to plg my notebook to normal LCD but still black screen ???
i think that problem is hotkey to bios recovery
any help ? any idea ?
11-16-2011 06:16 PM #2
There is your answer to your problem. In this situation I would RMA it (if you still got warranty on it) =/
Since you have done a bad flash, you bricked your BIOS and then won't work as it should.
Or you can buy something (don't remember what it's called, but it resets your BIOS) that would fix your bad flash.Asus G73SW-91058V 3D
- Intel Centrino Ultimate-N 6300
- BIOS 205
11-16-2011 06:46 PM #3
xeromist PC Specs Laptop (Model) Dell Inspiron 15 7567 Motherboard MSI x470 Gaming Plus Processor AMD 2600X Memory (part number) 16GB Crucial Ballistix Elite 3600 Graphics Card #1 ASUS GTX 1080 Strix Monitor BenQ BL3200PT Storage #1 Intel 600p NVMe CPU Cooler Wraith Case custom Antec 900 Power Supply Corsair HX1000 Keyboard Logitech Orion Spark Mouse Logitech MX500 Headset Plantronics 777 with Oregon Aero upgrade
- Join Date
- Jul 2010
- Reputation
- 318
- Posts
- 7,750
* Support disease research with Folding@Home *
< < < Click the drop-down above my avatar for my PC specs!
11-22-2011 08:59 AM #4MATRIX.REALGuest
it was not my problem
it because of asus live update
11-22-2011 09:16 AM #5
RMA it. That's the best advice. Sorry...
Read the User's Manual for more info.
G74SX-A1 BIOS 203
Intel 6230 WiFi/BT
LG E2350 LED LCD Monitor
Intel Series 510 120 GB SSD
Drivers, Apps and How To's
Latest nVidia Drivers
JRd1st on DeviantArt.com
11-22-2011 12:55 PM #6
Hmm.... your saying that you cant come into BIOS, but you can access your computer?
- BIOS 205
11-24-2011 05:46 PM #7MATRIX.REALGuest
no of course no
notebook just power on with black screen
11-24-2011 07:35 PM #8
Ok, then the best thing to do RMA your computer, a bad flash goes under warranty as I have understood.
So if you still got warranty on your computer call Asus Hotline and RMA it, if it's relatively new you could try to go back there you bought your notebook and ask for an exchange to a new one.
You could try one thing to see if it isn't a bad flash but a bad RAM, take out one RAM stick at the time and see if something changes.
It's just a thought, but I don't think it would work.Asus G73SW-91058V 3D
- BIOS 205
01-04-2012 12:40 AM #9
888-678-3688 to get your RMA started if in North America
01-04-2012 01:35 AM #10
..not to butt in on the thread...butt....
CHASTITY.................Well Welcome Back..
So very good to see your avatar's face.........Sorry.... As you were.
Similar Threads
ASUS G53JW Bios Update Problem
By adramora in forum ROG Gaming NotebooksReplies: 2Last Post: 10-27-2011, 06:20 PM -
Bootmgr/bios problem
By Arxon in forum ROG Gaming NotebooksReplies: 12Last Post: 09-18-2011, 10:47 PM -
[Problem] K53U Bad Bios
By sloox in forum TUF / Other Gaming NotebooksReplies: 1Last Post: 08-17-2011, 05:19 PM -
Problem With M4E Bios Display
By ~F&N~ in forum Other Series MotherboardsReplies: 2Last Post: 05-19-2011, 08:04 AM -
BIOS problem. G53 won't boot
By Gatsby in forum ROG Gaming NotebooksReplies: 0Last Post: 04-25-2011, 06:45 PM
