Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 43
  1. #21
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    28
    2,224
    Your not set to digital output instead of speakers, are you?
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
  2. #22
    Aug 2011
    28
    2,224
    When you open Realtek Sound Manager, do you see a speakers tab?
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
  3. #23
    Dray The Fingerless
    Guest
    Yes its set to speakers. but even then i couldnt alter it, because in the playback device it doesnt let me alter ANYTHING. as for the sound manager, yes, i have a speakers tab, but it doesnt let me select any default device or such
  4. #24
    Aug 2011
    28
    2,224
    Look in Control Panel, Sound, Playback. Is that what you were just talking about? Do you have any green markers next to devices?
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
  5. #25
    Dray The Fingerless
    Guest
    oh and i just found out something ironic. in realtek sound manager, in the microphone tab it lets me alter the microphone volume. i turned off somwhere the microphone feedback suppressor i guess, because when i increase volume, i get the annoying shriek of when you get a guitar tooclose to its amp. ironic how such an annoying sound makes me so happy, since it signals me my speakers still ****ing work.
    and yes, when i speak of playback devices , thats where the speakers show up, but it doesnt let me change anything, including not having a volume slider ANYWHERE.
  6. #26
    Aug 2011
    28
    2,224
    Did you try to enable any of them. Those aren't sliders they are bar meters, if you mean what I think you do.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
  7. #27
    Dray The Fingerless
    Guest
    it doesnt let me enable or disable ANYTHING. it just sits there, with the speakers enabled and set as default device.
  8. #28
    Aug 2011
    28
    2,224
    You mean, Speakers - Realtek High Definition Audio Ready?
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
  9. #29
    Dray The Fingerless
    Guest
    yes, it has the lil green check mark n everything. it doesnt say ready, it says default device, but i guess it only says ready when its NOT set as default device.
  10. #30
    Aug 2011
    28
    2,224
    Do you have anything like THX installed?
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
Similar Threads
  1. Realtek HD audio not found, HD Audio Controller cannot start Error Code 10
    By rabbert.klein in forum G Series Gaming Notebooks
    Last Post: 12-03-2011, 01:10 AM
  2. cannot install windows 7 - no new devices could be found.
    By fopsa in forum Other Series Motherboards
    Last Post: 10-08-2011, 09:50 AM
  3. cpu Level Up disabled question
    By mao8a87 in forum Other Series Motherboards
    Last Post: 10-06-2011, 08:57 PM
  4. No devices found, CPU fan error, and Windows not loading!!
    By mans686 in forum Other Series Motherboards
    Last Post: 09-27-2011, 02:45 PM
  5. P8P67 and ATAPI devices
    By Daybee in forum Other Series Motherboards
    Last Post: 01-21-2011, 07:40 PM
Tags for this Thread
