Results 1 to 10 of 148
Thread: Matrix 980 led indicator?
01-13-2015 07:23 AM #1
santz76 PC Specs Motherboard Rampage V Edition 10 Processor I7- 6850k 4.4ghz Memory (part number) GSkill Trident Z 64gb DDR4 3400hz Graphics Card #1 Asus Rog Strix GTX 1080 Graphics Card #2 Asus Rog Strix GTX 1080 Sound Card Sound Blaster Z Monitor Rog Swift PQ348Q curved monitor Storage #1 Corsair GTX Force 500 GB SSD Storage #2 Corsair force gt 500gb CPU Cooler Swiftech h240x custom apogee xl rog water block mayhems blood red coolant Case Corsair 760T Power Supply Corsair AX 1200I Keyboard Corsair k70 (cherry reds) RGB Mouse ROG GLADIUS Headset Astro A40 PC TR Editions Mouse Pad Asus ROG Sheath XL mouse pad OS Windows 10 / Samsung 950 pro M.2 Network Router Asus RT-AC87U Accessory #1 Saitek X52 Pro Accessory #2 DX Formula red/black gaming chair
- Join Date
- Dec 2012
- Reputation
- 11
- Posts
- 139
Hello I just installed my second matrix 980, and upon booting up, the card I just purchased led indicator is between blue and green in color, maybe a teel, where as bottom card is blue, Both on idle. So I did fresh install of drivers and nothing, I turned off pc took out card and upon looking at cover for led indicator with no power out of the system, I noticed that it has a yellow tint to it where as first card is plain white, so not sure how this card has a yellow type finish where indicator is. The card works perfectly except the led indicator color being slightly off, my question is should I rma it or just let it be!!!! sorry for horrible pics but i believe u can tell difference!!!
01-16-2015 03:39 AM #2
- Join Date
- Mar 2013
- Reputation
- 10
- Posts
- 30
01-16-2015 04:32 AM #3
- Join Date
- Oct 2012
- Reputation
- 339
- Posts
- 15,247
Hello.
When there is a light load the LED will glow blue which is normal. Now I'm not sure about the other GPU glowing green (Safe Mode). Give me some time and I will check for you.Last edited by Chino; 01-16-2015 at 04:34 AM.
01-16-2015 05:16 AM #4
- Join Date
- Mar 2013
- Reputation
- 10
- Posts
- 30
The LEDs themselves are glowing blue. The problem is the opaque panel the LEDs light up. On the good card (powered off) it's a very slight off white as it should be, but on the other card (also while powered off) it has a very yellowish tint. Due to the yellowish tint of the opaque panel, the light looks green.
As an addition test I did the following. With the cards out of the computer I shined a single white led down into the opaque panel. On the card that displays blue at idle, the opaque panel lights up with a slightly off-white glow. On the card that displays green at idle the opaque panel glows yellow. So the opaque panel (behind the ROG logo) is the problem. Yellow panel + blue lights = green ROG logo.
NOTE: As santz76 mentioned, it's not the green color like what is displayed in safe mode, but rather a turquoise green color.
Another note: My cards are sequential serial numbers.Last edited by kryptokatalyst; 01-16-2015 at 05:21 AM.
01-16-2015 08:02 AM #5
- Join Date
- Dec 2012
- Reputation
- 11
- Posts
- 139
Ya I rma'd mine from newegg I took my card out and noticed when the led indicator panel with no power had a yellow tint to it, and my first one was solid white, so you could tell they were both blue but one with yellow tint was coming off as a teal color, it drove me nuts lol!!! But now unfortunatly newegg is out of stock
as of today but my rma will arrive at there location on Monday so hopefully will be back in stock then, by the way I checked with safe mode and this was not the case!!
01-16-2015 08:06 AM #6
- Join Date
- Dec 2012
- Reputation
- 11
- Posts
- 139
Side note I purchased first one December 19th and second on January 9th, dam sure hope replacement is does not have same issue!!!
01-19-2015 08:14 PM #7
- Join Date
- Mar 2013
- Reputation
- 10
- Posts
- 30
I spoke with Newegg support and since the item is not in stock they would not do an advanced RMA. I'm inclined to keep this one until I have another in my hands. Due to limited stock I don't want to get in a situation where I send the card back to Newegg and then wait on their stock to replenish only to find out they won't be getting anymore. In such a case I'd be stuck with 1 card and that doesn't do me any good.
If Newegg doesn't have more tomorrow I am going to submit an advanced RMA with ASUS.
01-20-2015 12:09 AM #8
- Join Date
- Dec 2012
- Reputation
- 11
- Posts
- 139
now I'm thinking prob should have done the same with asus, but rog on Facebook messaged me and said north americe would get more end of January. If not you can order from amazon as well but will ship between 22 and 27 days so I'll be patient
01-20-2015 12:42 AM #9
- Join Date
- Mar 2013
- Reputation
- 10
- Posts
- 30
01-20-2015 01:23 AM #10
- Join Date
- Dec 2012
- Reputation
- 11
- Posts
- 139
Ya me too, just got my refund today
little sad I have to wait for sli ing these bad boys!!! What sucks is when I did do rma with newegg they were still in stock!!! So i monitored all weekend then of course on Sunday they were all gone, so now I have the joy to check every 5 minutes to see if they are in stock!!!!
