Page 3 of 15 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 148
  1. #21
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    164
    7,454
    If you can get me the RMA number I might be able to get someone to trace it.
  2. #22
    ROG Guru: Yellow Belt Array santz76 PC Specs
    santz76 PC Specs
    MotherboardRampage V Edition 10
    ProcessorI7- 6850k 4.4ghz
    Memory (part number)GSkill Trident Z 64gb DDR4 3400hz
    Graphics Card #1Asus Rog Strix GTX 1080
    Graphics Card #2Asus Rog Strix GTX 1080
    Sound CardSound Blaster Z
    MonitorRog Swift PQ348Q curved monitor
    Storage #1Corsair GTX Force 500 GB SSD
    Storage #2Corsair force gt 500gb
    CPU CoolerSwiftech h240x custom apogee xl rog water block mayhems blood red coolant
    CaseCorsair 760T
    Power SupplyCorsair AX 1200I
    Keyboard Corsair k70 (cherry reds) RGB
    Mouse ROG GLADIUS
    Headset Astro A40 PC TR Editions
    Mouse Pad Asus ROG Sheath XL mouse pad
    OS Windows 10 / Samsung 950 pro M.2
    Network RouterAsus RT-AC87U
    Accessory #1 Saitek X52 Pro
    Accessory #2 DX Formula red/black gaming chair
    santz76's Avatar
    Dec 2012
    11
    139
    OK pm sent, hope you can let us know something. By the way thank you! It's nice to see someone so concerned and trying to find the problem, so again thanks! I will be receiving my second card today so I will post update
  3. #23
    santz76 PC Specs
    CaseCorsair 760T
    Mouse ROG GLADIUS
    santz76's Avatar
    Dec 2012
    11
    139
    Well unfortunately I have same issue with new card I received today Click image for larger version.
ID:	45747Click image for larger version.
ID:	45747 here is a pic of what issue is I really don't want to have to send second one back DAMM IT!!!!
  4. #24
    santz76 PC Specs
    CaseCorsair 760T
    Mouse ROG GLADIUS
    santz76's Avatar
    Dec 2012
    11
    139
    So bottom card is blue and top card has the teal color same issue with rma'd card!!! Do II have any solutions available to me?
  5. #25
    ROG Enthusiast Array
    Mar 2013
    30
    Quote Originally Posted by santz76 View Post
    Well unfortunately I have sane issue with new card I received today Click image for larger version.
    WOAH!!! What the heck is going on!? This is insane. It's 100% caused by the LED diffuser panel, which is about a $0.25 part!
    Really sorry to hear that man! I feel for you.
  6. #26
    santz76 PC Specs
    CaseCorsair 760T
    Mouse ROG GLADIUS
    santz76's Avatar
    Dec 2012
    11
    139
    Sucks at this point not sure don't wanna go through another rma, this sucks unless RAJA@ASUS can figure something out for me!!!
  7. #27
    Mar 2013
    30
    Quote Originally Posted by Raja@ASUS View Post
    Hi Guys,
    This is a normal situation when using SLI.
    ROG logo = green means the GPU is under very light load.
    While using SLI, the LED indicator might be a little different, the loading of master GPU will be heavier than the 2nd GPU.
    So in idle mode, master GPU = blue, 2nd GPU = green.
    While running 3Dmark11, master GPU may be red, and another may be orange.It’s a normal situation in using SLI.
    Basically RMAing the cards for this won't help - it's down to how SLI loads the cards. The color of the LEDs on the cards is purely load dependent and as SLI isn't perfectly load balanced, what you are seeing is normal.
    -Raja
    Raja,
    As I explained in great detail to Raj. B when I filed for an RMA, the problem is as santz76 says. The Edge Lit LED Diffuser Panels are inconsistent in coloring, which is explained IN DETAIL in this forum.
    If you take each card in your hand, outside of the computer, and manually shine a white led on the top edge of the LED diffuser panel the color you see through the load indicator window is different for each card. Again, due to the diffuser panel coloring being drastically different.
    santz76's most recent images show it VERY clearly. The cards are powered off and just with ambient light you can clearly see one opaque panel is white, and the other is definitely yellow. If blue light is emitted into a white diffuser panel, the diffuser panel will illuminate blue. However, if blue light is illuminated into a YELLOW diffuser panel, then the diffuser will illuminate green. Therein lies the problem.
    Really frustrating problem for such an awesome card, especially for us SLi users who have two cards right next to one another.
  8. #28
    Mar 2013
    30
    What's really crazy is that the card I have that seems to be okay, the opaque panel is not nearly as white as your good one. I think ASUS has an issue with the supplier of the opaque panels. They're obviously getting components with extremely inconsistent diffuser coloring. I'm really glad you were able to get some good pics with the cards powered off. You can see the problem clearly. Blue and yellow make green, no two ways about it.
  9. #29
    santz76 PC Specs
    CaseCorsair 760T
    Mouse ROG GLADIUS
    santz76's Avatar
    Dec 2012
    11
    139
    Ya its a real shame!!! Just not sure where to go from here hopefully raja can help, did you send your bad one back krypto?
  10. #30
    Mar 2013
    30
    I still have both of mine, 1 good, and the 1 bad. The new card is on the way, and if it's good I will RMA the bad card back to Newegg. That is unless something is worked out with ASUS to send the card to them, which I'm happy to do.
    I'm a computer engineer by trade and take stuff like this apart all the time. I've been tempted to removed the shroud and removed the LED PCB to get clear pictures of the problem, but hopefully it won't come to that.
