ROG Swift & G-Sync problems in 2way SLI?
1sthurricane
Has anyone that owns this monitor had problems with G-sync and 2way SLI setups?I am currently in a build with x2 980 SC Reference cards in SLI. I am aware there are numerous driver problems and I play a ton of BF4/All Total War Titles/Company of Heroes 2 and wondered what to expect.
17 REPLIES 17
simfreak101
In total war: shogun 2, the background will flicker while moving the mouse on the map screen. Does not happen in battles.
I run 3 with 3 980's in surround mode.
Tot2 is set to v-sync enabled and v-sync is set to gsync in the nvida control panel.
I dont play battlefield.
zimzoid
I play the games you do and have 2x gtx780s, mostly playing bf4 and gsync is working great with sli I play at 120hz
4930k/Corsair H110i GT: Rampage IV Black ED motherboard: Gskill 4x4GB 2133MHZ 10 11 11 30 1T: CM V1200w Platinum psu: 2x EVGA GTX980Ti SC ACX++: SoundBlaster Zx: Logitech Z906 5.1-channel speaker system: Samsung 850 EVO 500GB SSD: 1tb WD Black HD/512GB WD Black HD: Asus Swift 144HZ 3D 2560x1440 Display: QNIX QX2710 Evolution II 2560x1440 matte PLS display: Corsair Vengence K70 mechanical keyboard: Corsair M45 mouse: Thermaltake Core V71 full tower Case: Windows 10 64bit
If I may ask.......what drivers are you currently using?And why not refreshing @144mhz?
No worries, using 344.75 and the reason for 120hz is that i like to max out most of my settings except AA and can hold a constant 120fps with 144hz it drops occasionally. Actually cant really notice any difference between 120 and 144 so i use 120hz less stress and temps on my system;)
I play alot of BF4,if you ever wanna rape it up together send me an invite to 1sthurricane!
zimzoid
Yay new driver today 347.25 WHQL
1sthurricane
Thanx for the 120mhz advice,currently in a build and can't wait to see BF4 on this ROG monitor!
zimzoid
Ok mate will do, at work at the moment will send you an invite later, choppernNZ is my game name
1sthurricane
If you don't see me 2nite it will be soon.Having to download my Origin and Steam accounts onto new rig.Hmmmm.....mate you say...either your a "tosser" from the island of the Queen or I think...... an Aussi or a kewl Kiwi!
