Results 1 to 3 of 3
    New ROGer Array pr0_g4nxta PC Specs
    pr0_g4nxta PC Specs
    MotherboardAsus ROG Rampage IV Black Edition
    ProcessorIntel i7-3930k
    Memory (part number)8GB Kingston HyperX 2400Mhz
    Graphics Card #1Asus StriX GTX 980 OC Edition
    MonitorAsus VG248QE 144Hz 3D
    Storage #1Asus ROG Raidr SSD 256GB
    Storage #2Samsung 500GB HDD
    CPU CoolerCorsair H100i (2x120mm & 2x140mm Noctua Industrial PPC 3000RPM)
    CaseNZXT Phantom 820
    Power SupplyNZXT Hale90 V2 850W
    Keyboard Microsoft Reclusa
    Mouse Asus ROG GX1000 Eagle Eye
    Headset Sennheiser G4ME ZERO
    OS Windows 7 x64
    Jan 2013
    2
    ROG Frot Base Sound-Issue
    Hey Guys,
    i've bought me a new Asus ROG Front Base. First i've made a new BIOS-Update, then ive installed a few drivers and a new version of AISuite 3... Everything works fine, overclocking, hiding screen and fan-controls... but only the sound. Maybe i've made a mistake, but i can choose what i want in this Realtek-Audio Manager, nothing works...
    I also can choose those EQ-Settings with the Front Base (for example "Racing" or "Music" etc..) or the volume, but i've got no sound.
    I've tried it with AC97 and HD-Audio, both doesnt work... I dont know why.
    When i put a audio-cable into the back of my rig, the RT-Audiomanager pops up with a hint of "cable was disconnected or connected"
    But when i put a cable into the front of the ROG Base, nothing pops up or something...
    Thanks for help! And sry for my not so good english ;-)
    Greetz from Germany!
    My Specs:
    Intel I-7 3930K
    8GB Kingston HyperX DDR3 2400Mhz
    Asus RAIDR 256GB
    Asus StriX GTX 980
    ROG Guru: Yellow Belt Array Deon017 PC Specs
    Deon017 PC Specs
    MotherboardASUS Rampage IV Extreme Black Motherboard
    ProcessorIntel Core i7 4960X Extreme Edition
    Memory (part number)Corsair Vengeance Pro CMY32GX3M4A2133C11 32GB
    Graphics Card #1Asus Poseidon GTX 980Ti
    MonitorAsus Rog Swift 27" 3D Monitor
    Storage #1ASUS RAIDR Express 240GB PCI-E SSD
    Storage #2HDD: Intel 520S 240GB SSD
    CPU CoolerEK Supremacy Elite CPU Waterblock for Intel 2011
    CaseCorsair Obsidian 900D Super Tower Case
    Power SupplyCorsair AX1200i Digital ATX Modular Power Supply
    Keyboard Logitech G19s Gaming Keyboard
    Mouse Asus ROG Gladius
    OS WIN 10
    Network RouterAsus RT-AC3200
    Deon017's Avatar
    Aug 2013
    147
    Hi - just things to check - you have plugged the audio cable to your internal audio connector to you RIVBE and is it enabled in your Bios - you have installed the correct audio driver for the RFB - it has it's own sound driver - check under your device manager - I had the same problem and found that the cable connector on the RFB was not inserted totally -
    Hope this helps
    pr0_g4nxta PC Specs
    OS Windows 7 x64
    Jan 2013
    2
    Thanks for the quick reply, but yeah ive checked everything...
    I saw that the Power-cable wasnt connected totally, but nothing changed..
    After a few hours work and keyboardsleeps i found the fu**ing problem! (But i think it wasnt a problem - more than a trick)
    I started my computer until its working, then i've done it like plug & play at running system!
    Ive connected this AAFp-cable again and see there it works! A second later the popup from the audio-manager comes up and says audio-cable connected!
    But now ive got a new problem, evertime theres a crackling and jittering noise.. I changed my volume from my headset to minimum and have to change the VOL from my computer to hear very clear sounds... (and its only at the Front Base, not at the back of my RIVBE)
    Thanks for help!
    Greetings from Germany!
