Results 1 to 6 of 6
    TheFuzzleFluff
    Guest
    Exclamation g73jh-freak graphics problems
    I have a freak problem- that makes zero sense with my graphics card
    an
    Amd mobility Radeon Hd 5800
    When I attempt to stream videos or enter battery mode the card seemingly breaks
    the temperatures on the card at this time DECREASE
    I have changed drivers, reflashed BIOS, tried the GSOD fix,
    However, playing games like counterstrike, Tf2, minecraft, JustCause2 work fine with no problems
    Im at a loss here, and would really appreciate some help
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    28
    2,224
    What kind of viideos format?
    Did you flash your vbios or bios recently? If so, can you revert back?
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
    TheFuzzleFluff
    Guest
    Flash vids work fine
    things off youtube and hulu cause this
    I did flash the Bios and Vbios in an attempt to fix the problem- neither one did
    currently both the Vbios and the Bios are set to the stock ones on the Asus Site
    TheFuzzleFluff
    Guest
    Update!
    I diagnosed the problem even more, i think the original error is caused hardware damage on the card itself.....
    oddly enough, internet explorer CAN stream videos
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    89
    4,437
    If you connect to a 2nd monitor or LCD TV, does it also display the video corruption?
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
    Aug 2011
    28
    2,224
    I have a feeling it's a hardware issue. Make a hard copy of that screen and include it if you RMA. Tell them it's a heat and that it takes a long time, sometimes, to pop up: they may just replace the Motherboard. ;p
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
Similar Threads
  1. G73jh having battery problems
    By pnikkosis in forum G Series Gaming Notebooks
    Last Post: 06-15-2013, 10:51 PM
  2. Graphics Card Problems-G73jh
    By TheFuzzleFluff in forum G Series Gaming Notebooks
    Last Post: 11-13-2011, 06:21 AM
  3. Help with G73JH graphics card going out?
    By Del87 in forum G Series Gaming Notebooks
    Last Post: 07-30-2011, 01:02 AM
  4. G73JH-A1 graphics issue
    By Loki in forum G Series Gaming Notebooks
    Last Post: 07-07-2011, 09:50 PM
  5. Frustrating problems with G73JH :(
    By M4rkh0lm in forum G Series Gaming Notebooks
    Last Post: 03-25-2011, 09:15 PM
