Results 1 to 10 of 13
02-26-2015 11:34 AM #1xforever82Guest
I am a newbie to overclocking and I need help
I decided to buy a rampage v and i7 5960x
With corsair ddr4 2666mhz
I do not want to over clock my cpu I want to use it as normal
Currently I set xmp for bios but when I check the task manger I still see its at 3.24ghz what should do?
As I am in a total lost mode
Please help me thanks
02-26-2015 02:41 PM #2
- Join Date
- Oct 2012
- Reputation
- 339
- Posts
- 15,247
If you want to check your CPU's frequency, use CPU-Z instead. Enabling XMP will not overclock your CPU.
02-26-2015 03:38 PM #3
AdamC PC Specs Motherboard R5E Processor i7 5930k Memory (part number) 8 x G.SKILL Ripjaws F4-3000C15Q-16GRBB Graphics Card #1 MSI GTX980Ti Graphics Card #2 MSI GTX980Ti Monitor 3 x BenQ BL3201PH Storage #1 SAMSUNG XP941 512G Storage #2 Too many to list CPU Cooler Noctua NH-D15 Case Rosewill THRONE-W Power Supply EVGA 220-P2-1200-X1 OS Windows 7 64 Ultimate
- Join Date
- Dec 2014
- Reputation
- 27
- Posts
- 136
XMP uses 125 strap so a 24 multiplier should give you 3000MHz. I believe that is the default 5960 speed. Probably you have 26 multiplier now, which will give you 3250 MHz.
02-26-2015 09:05 PM #4xforever82Guest
Thanks a lot so is xmp good?
02-26-2015 10:10 PM #5
- Join Date
- Dec 2014
- Reputation
- 27
- Posts
- 136
Good for beginners. You will always get a better result if you set it up manually. You can use strap 100 if you set the dram timing and voltage manually. Then your cpu will be at rounded number like 3000 3100 3200 3300 depending on the multiplier you set.
02-27-2015 02:11 AM #6xforever82Guest
Thanks Adamc do u have any link where I can set manually for the best result without over clocking
I am using 5960x and corsair vengeance 16g 2666mhz cmk16gx4m4a2666c16
I see from other forum that the bench mark is not good when we set cpu strap to others expect for 100
Plz give me some guide thanksLast edited by xforever82; 02-27-2015 at 02:15 AM.
02-27-2015 05:31 AM #7
- Join Date
- Oct 2012
- Reputation
- 339
- Posts
- 15,247
You'll find that it's easier to use the 125 Strap for memory above 2400MHz. Depending on the quality of your RAM and your patience to tweak it, running 2666MHz on the 100 Strap is possible.
02-27-2015 07:29 AM #8xforever82Guest
02-27-2015 07:52 AM #9xforever82Guest
02-27-2015 08:31 AM #10
zcrucifix PC Specs Motherboard Rampage V Extreme Processor Core i7 5960x Memory (part number) F4-2800C15Q2-64GRK Graphics Card #1 POSEIDON GTX980 Storage #1 Intel 730 240GB - x3 Raid 5 Storage #2 WD Black 2TB - x2 Raid 1 CPU Cooler EK Supremacy EVO Case Corsair 900D Power Supply EVGA 1000 P2 Keyboard Razer BlackWidow Mouse Razer Naga Epic Headset Astra A50 OS Windows 8.1
- Join Date
- Aug 2013
- Reputation
- 10
- Posts
- 4
Your volts are reasonable and memory is set at factory XMP, so if you are planning to run 24/7, it looks good. If you decide you want to tweak things down the road, you have plenty of room to do it.
