Results 1 to 10 of 10
    New ROGer Array zcrucifix PC Specs
    zcrucifix PC Specs
    MotherboardRampage V Extreme
    ProcessorCore i7 5960x
    Memory (part number)F4-2800C15Q2-64GRK
    Graphics Card #1POSEIDON GTX980
    Storage #1Intel 730 240GB - x3 Raid 5
    Storage #2WD Black 2TB - x2 Raid 1
    CPU CoolerEK Supremacy EVO
    CaseCorsair 900D
    Power SupplyEVGA 1000 P2
    Keyboard Razer BlackWidow
    Mouse Razer Naga Epic
    Headset Astra A50
    OS Windows 8.1
    Aug 2013
    4
    Overclocking a 5960x on RVE
    I wanted to see if someone had any ideas on how I could possibly push my overclocks further. I've read all the posted guides, and frankly, I'm at a loss as to why I can't get any more performance. It may come down to silicon lottery, but I figured I needed to ask for advice before I go buy another processor. No matter what changes I make, I cannot get 4.6Ghz to run stable. I can run a 35 multiplier at 125 BCLK and everything is amazing at 1.35 volts, but even overvolting the CPU to 1.55-1.65 results in a crash. I am not even close to the thermal envelope on the processor, so I hoped someone with a little more experience may be able to give me a little guidance. Thanks!
    Edit - to clarify, the crash I am getting is the clock watchdog timeout - stop 0x00000101, and I've tested to make sure it's not cache related, or memory related.
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,718
    A 4.6GHz@1.35V is already a "better than average" 5960X overclock.
    x125MHz BCLK forces everything to run on tighter tolerances. x100MHz BCLK may not be as spectacular, but it can allow a lot more overall fine tuning, to tweak a little bit more performance out of threshold subcomponents - you could be held back by some "weak" part which can't quite keep up at higher base frequency. But I doubt you can tweak a lot more out of your particular part - then again, I could be wrong. You're already pushing past what I personally consider the stability threshold if you're getting the odd crash.
    You might be able to deactivate your "slowest" cores to push the remaining cores slightly faster.
    I've never pushed much past 1.4V, the sweet spot for my particular CPU, because higher voltage ramps up heat (and plunges stability, and wears against longevity) exponentially fast.
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    164
    7,454
    Clock watchdog timeouts mean the processor is at the edge of stability. If there is no room for VCore (which there is not), or temps can not be lowered with better cooling, I would leave the system be. Settle on a lower clock where the CPU is comfortable.
    ROG Guru: Green Belt Array FlanK3r PC Specs
    FlanK3r PC Specs
    MotherboardROG Crosshair VII Hero WiFi
    ProcessorAMD Ryzen 7 3800X
    Memory (part number)G.Skill TridentZ Neo RGB 2x16GB 3600MHz
    Graphics Card #1Asus Dual RTX 2060 O6G
    Graphics Card #2Asus Radeon R3 230
    Graphics Card #3Saphire R9 270X Toxic
    Graphics Card #4ROG GTX980TI Poseidon
    MonitorAOC 27"
    Storage #1Samsung 850 PRO 512 GB
    Storage #2HyperX 3K 240GB
    CPU CoolerROG Ryujin 240
    CaseLian-Li Dynamic O11 XL + NZXT Noctis
    Power SupplyCM V850 + Corsair TX750
    Keyboard Microsoft Sidewinder
    Mouse Razer Deathadder Elite
    Headset HyperX Cloud + ROG Strix Go 2.4
    Mouse Pad Roccat Tatto
    Headset/Speakers ROG Magnus
    OS Windows 10 + Windows 7
    Network RouterAsus DSL-AC88U
    FlanK3r's Avatar
    Sep 2010
    110
    604
    4.6 GHz is really high. I have two 5960x and one is around 4350 MHz stable and second 4450 MHz stable.
    Who knows me, knows me ....AMD 3000+, AMD x2 4600+ EE, AMD X4 955 BE C2,2x AMD X4 965 BE C3, AMD X4 970 BE C3, AMD x4 975 BE, AMD x4 980 BE, AMD X6 1090T BE, AMD x6 1100T BE, 2x AMD FX-8120, 2x AMD FX-8150, FX-6300, FX-8300, FX-8320E, FX-8320, FX-8350, FX-8370, FX-8370E, FX-9370, FX-9590, AMD A8-3850, AMD A8-3870K, A8-5600K, A10-5800K, A10-6800K, A10-7850K, A10-7870K, A 5150, Athlon x4 860K, Intel i7-5960X, i7-6700K, Intel i7-4770K, Intel i7-980x, Intel i7 2600k, Intel i7-3770K, i7-3930K.
    ROG Guru: Brown Belt Array Antronman's Avatar
    Dec 2013
    29
    1,374
    More and more cooling.
    Clearly you're not afraid of voiding the warranty.
    So might as well "change" it up.
    If you know what I mean
    You'll need one of these for starters
    Say hi to the next generation.
    Peace is a lie, there is only Passion
    Through passion, I gain strength
    Through strength, I gain victory
    Through victory, my chains are broken
    The Republic of Gamers shall free me
    New ROGer Array
    Mar 2015
    4
    I think you will find your cpu is at its limit, my 5960 will do
    4.5ghz 1.23v cache is set at x34 cache volts is 1.21v bclk is 125 memory is at 3000mhz all stable , temp 34c idle 64 load
    4.625ghz 1.56v cache is set at x34 cache volts is 1.21v bclk is 125 memory is at 3000mhz all stable ,temp 34c idle 64- 70c load
    4.75 ghz 1.34v cache is set at x34 cache volts is 1.21v bclk is 125 memory is at 3000mhz all stable, temp idle 34c 93c load
  7. #7
    ROG Guru: Brown Belt Array Brighttail PC Specs
    Brighttail PC Specs
    Laptop (Model)Asus G751JT
    MotherboardAsus x299 Rampage VI Extreme
    ProcessorIntel i9-7900x
    Memory (part number)Corsair Dominator Platinum SE 3200Mhz 4x8
    Graphics Card #1MSI GTX 1080TI
    MonitorAcer XB321HK (4k,IPS,G-sync)
    Storage #1Intel 900p (Boot) 2xSM961 (RAID 0) Games
    Storage #2Samsung 850 Pro 512GB - WD Black 4TB
    CPU CoolerCustom Water Cool
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX 1200i
    Keyboard Corsair Platinum 95
    Mouse Asus SPATHA
    Mouse Pad Corsair MM800
    Headset/Speakers Kanyo Y5
    OS Windows 10 64 bit
    Accessory #1 2 x Alphacool Full Copper Radiator 420mm/280mm
    Accessory #2 Monsoon MMRS reservoir w/ 2 x D5 Vario Pump
    Accessory #3 Monsoon Free Center Compression Fittings
    Sep 2014
    33
    1,336
    Quote Originally Posted by wildeone View Post
    Interesting at a lower clock you are using .2 more volts. Was that a mistype?
    Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator RGB 3200MHz
    MSI GTX 1080 TI / 2x Intel 900p / Samsung 970 Pro 512GB
    Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
    Corsair AX 1200i / Corsair Platinum K95 / Asus Chakram
    Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
  8. #8
    ROG Enthusiast Array
    Jul 2016
    44
    Have you played with cpu input voltage and cache voltage? I found running my input voltage at 2v really helped my chip and meant i could stay under 1.375v core (big help to load temps).
    Cache voltage also helped a lot for me, but i also now have my cache running at 4.6 @ 1.3v. Just make sure your board is kept cool at input voltages this high.
    I myself have a xeon 1680v3 (basically a 5960x) running at 4.8 @ 1.35v under water. Max cpu package temps inder real bench stress is just under 80c so perfectly fine for gaming etc.
    Can i ask what youve set you power / vrms up at? You can try messing with those a little in conjunction with spread spectrums etc.
    Also have you tried diffeent load line calibrations settings? If your very cold you may get some milage there.
    You still have a very good clock there for haswell 8c! Whats your load temps?
  9. #9
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    21
    1,476
    I believe you request to much from your processors. He behave best up to 4.3GHz with good number of samples capable to work up to 4.5GHz.
    How long... that's different question. Better 4.3GHz 5 years then 4.5GHz 1-2 year.
  10. #10
    ROG Member Array Silverbullit PC Specs
    MotherboardAsus Maximus XI Extreme (Bios 1502)
    Processori9 9900K (Stepping P0)
    Memory (part number)F4-3200C14D-32GTZR
    Graphics Card #1Msi 2080 Ti OC Gaming X
    MonitorLG C9 65" & LG 4700 47" 2ms 1920P 60Hz
    Storage #1SSD M.2 970 Plus Samsung MZ-V7S1T0, 1000 GB, 3500 MB/s
    Storage #216TB Exos (261MB/s)
    CPU CoolerAqua Computer Kryos Next Vision 1151 Custom loop 7 Radiators asf
    CaseThermaltake Core P7 Tempered Glass Edition
    Power SupplyCorsair Ax1600i
    Keyboard Razer Huntsman Elite (And for writing: Microsoft 4000 V1 Ergonomic)
    Mouse Logitech G903
    Headset Arctis 7 Wireless
    Mouse Pad Steelseries
    Headset/Speakers Logitech 2.1
    OS Windows 10 Pro (Build 10.0.18632)
    Accessory #1 4TB Seagate Ironwolf Transfer Rate 263,38 MB/s 2107 MB/s
    Accessory #2 4TB Seagate Ironwolf Transfer Rate 263,38 MB/s 2107 MB/s
    Accessory #3 Dual D5 Next, 8 Rads
    Silverbullit's Avatar
    Apr 2019
    17
    My x5690 doesnt run solid below 1,42V (Core) @ 4452 dram @ 1866 with solid timings including 1T/1N. Something happens when I hit 1,42V because the x5690 refuses to pass any stresstest above 4000 (@ default max 1,35V) and suddenly it runs every stresstest all the way up to 4452 with a smile. *weird, my other cpus does not act this way* But yeah right, obvious Core voltages way to high already, can get higher at silly voltages but the dram plummets to only work at lowest speeds maxed out timings. It feels uncomfy going over 1,35V but capped at 4000 on a costly x5690 feels beating its own purpose. So in good OC spirit thinking Kurgan has a point in his wisdom "Its better to burn out than faint away". Got 6x4gb ddr3 but for some weird reason it reads two sticks as 2gb!?! (Printed 4gb on all six...)
    4,3 at 1,35V - no way with my chip, guess I'm not good at picking winning silicon auctions.
