Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    ROG Enthusiast Array
    May 2011
    25
    What do you guys call this problem?
    What is this called? cant search forums if i don't know what this is called >.<
    BTW I was talking in Tagalog(Philippine National Language) in the video. >.<
    Basically, what I said was, I connected my Laptop to the TV
    http://s237.photobucket.com/albums/f...t=DSCF0002.mp4
    Laptop
    TV
    Laptop using High Contrast Black appearance
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    89
    4,437
    I'd call it a reddish corrupt video display.
    Are you running any temperature monitoring software? If so, what is the GPU temp?
    What model ASUS laptop is that? What version video driver are you running?
    Since it does not appear to affect your 2nd monitor, I would suspect a poorly connected or faulty laptop LCD video cable.
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
    May 2011
    25
    Dont have any temp monitoring software, model is G73SW-A1 and Video driver Version is nVidia Forceware 285.64
    Sep 2011
    89
    4,437
    If you just purchased this laptop, I would contact the retailer and see if you can exchange it for a new one.
    ROG Guru: Blue Belt Array fuzon1337's Avatar
    Sep 2011
    18
    878
    Hi
    You can download HWInfo32 from the thread New Drivers and when you have installed that, you can read the temp in CPU/GPU.
    I would also say the same as dstrakele:
    Quote Originally Posted by dstrakele View Post
    I'd call it a reddish corrupt video display. Since it does not appear to affect your 2nd monitor, I would suspect a poorly connected or faulty laptop LCD video cable.
    So if you don't want to open up your computer I would RMA it or change to a new one if you bought it recently.
    But was the screen like that before? Or did it appear when you updated your graphic card?
    Asus G73SW-91058V 3D
    - Intel Centrino Ultimate-N 6300
    - BIOS 205
    May 2011
    25
    I bought the laptop last April 25. Its just that I bought it in the US but I am a resident of the Philippines, I was informed when I purchased the laptop that it has an International Warranty, then I found out that It only had national warranty for the U.S. @_@
    Do you think its possible if I send it to them Via Mail? So I can avail of the warranty.
  7. #7
    May 2011
    25
    Quote Originally Posted by fuzon1337 View Post
    Hi
    Yep, It Appeared when I updated my driver so I could play BF3
  8. #8
    Sep 2011
    89
    4,437
    That doesn't sound right to me. I was under the impression all ASUS Laptops have a Global Warranty. I recommend you PM Brian@ASUS or Mason@ASUS to get the correct story on the warranty.
    On http://commercial.asus.com/warranties, I see:
    ASUS 360 Warranty: A comprehensive 2 year global notebook warranty that includes a flawless display (zero bright dot) guarantee, free two way standard shipping for RMAs, and 24/7 US-based tech support
  9. #9
    May 2011
    25
    Thank You dstrakele you've been a Big help.
  10. #10
    Sep 2011
    18
    878
    Hmm, but rodney said that this issue occurred when he updated his graphic driver,
    so perhaps you should try to downgrade the driver version to see if that fixes it, or do a clean install and then install the drivers on the asus support to see if there is any change?
    (If you don't already have done that of course)
    If you have done that, stand to what dstrakele says
    - BIOS 205
Similar Threads
  1. PRE-FLOOD Pictures - Too Close To Call, Yet.
    By chrsplmr in forum General Discussion
    Last Post: 09-17-2011, 03:37 AM
  2. Off topic, but you guys the best.
    By TechJackass88 in forum Other Series Motherboards
    Last Post: 08-28-2011, 07:34 AM
  3. you guys want to see a worklog for this?
    By DarthBeavis in forum Case Modding & PC Builds
    Last Post: 06-23-2011, 06:26 PM
Tags for this Thread
