Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Enthusiast Array KMandalore PC Specs
    KMandalore PC Specs
    MotherboardAsus Maximus Formula Vi
    ProcessorI7 4770k
    Memory (part number)Corsair Dominator 1866 2x 8Gb
    Graphics Card #1Gtx 780 poseidon
    Graphics Card #2Gtx 780 poseidon
    CaseStorm Stryker White
    Power SupplyThermaltake 850 watts smart
    OS Windows 7 Ultimate
    Jun 2014
    30
    What pump & reservoir should i use to cool my system?
    I have a Intel I7 4770k and a Formula VI mobo with 2 gtx 780s.
    I have been looking at the following pumps and combos.
    XSPC Twin D5 Dual Bay Reservoir/Dual Pump Combo
    XSPC D5 Photon 270 Reservoir/ D5 Vario Pump Combo
    XSPC Twin DDC Dual Bay Reservoir/Pump Combo
    The photo is included to show you what i need to cool incase i didn't explain well
    this is the last step in my water cooling build any suggestions?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hello KMandalore
    Decisions Decisions I know haha.
    Have you seen the aquacomputer aqualis reservoirs? Lots of options to choose from, I looked at these for a couple days. Some are stand alone and some can be a pump/res combo. They are glass reservoirs and won't ever stain.
    https://www.aquatuning.us/search?sSearch=aqualis
    Here is one from frozencpu.com you can get installed but as I understand frozencpu is having problems and will be down for a little while.
    http://www.frozencpu.com/products/16...Installed.html
    Decisions Decisions
    KMandalore PC Specs
    ProcessorI7 4770k
    Jun 2014
    30
    To be completely honest i have no idea where to start on the pump and res. I wasn't going to use any dyes just plain ol distilled water.. so im not
    concerned about the stains.
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    If it were me I would probably do a pump/res combo of either (bay res or cylinder), it would keep it all together and not take up as much space.
    Or just let your imagination run wild.
    KMandalore PC Specs
    ProcessorI7 4770k
    Jun 2014
    30
    I wanted to to do a bay/ pump combo and if there wasn't enough water use a resevoir w/o a pump. Unfortunately because of my case set up the res/pump combo has to be in the lower most bay from leakage fears i'm unwilling to put my HDD below the res.
    KMandalore PC Specs
    ProcessorI7 4770k
    Jun 2014
    30
    I also didn't know if since i'm coolin for components if i should try to cool it all with one loop or if i should use a dual res/pump combo one private
    loop for the gpu's and one loop for the cpu/mosfet.
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    1 gtx 780 can draw a maximum of about 250 watts or a little more so 2 of them would draw a little over 500 watts, add in your 4770k which is 84 watts and you have about 600 watts of heat to dissipate. The mosfets don't create too much heat so you can add them in there, normally they are passively cooled.
    One 360 radiator is capable of dissipating 600 watts of heat so you could get away with one loop, but you will more than likely have to have a push/pull configuration with your fans and a good pump for good flow.
    Another way to look at it is put a 120mm rad for each component and you have a 360 rad. So yeah you could do it all in one loop.
  8. #8
    ROG Guru: Yellow Belt Array Deon017 PC Specs
    Deon017 PC Specs
    MotherboardASUS Rampage IV Extreme Black Motherboard
    ProcessorIntel Core i7 4960X Extreme Edition
    Memory (part number)Corsair Vengeance Pro CMY32GX3M4A2133C11 32GB
    Graphics Card #1Asus Poseidon GTX 980Ti
    MonitorAsus Rog Swift 27" 3D Monitor
    Storage #1ASUS RAIDR Express 240GB PCI-E SSD
    Storage #2HDD: Intel 520S 240GB SSD
    CPU CoolerEK Supremacy Elite CPU Waterblock for Intel 2011
    CaseCorsair Obsidian 900D Super Tower Case
    Power SupplyCorsair AX1200i Digital ATX Modular Power Supply
    Keyboard Logitech G19s Gaming Keyboard
    Mouse Asus ROG Gladius
    OS WIN 10
    Network RouterAsus RT-AC3200
    Deon017's Avatar
    Aug 2013
    147
    with one loop just have a radiator after each component - one after your cpu and one after your GPU's and from the last one back into your res - I have just changed mine from dual loop to single and there is very little difference in temps, but then I have 2 x 420 radiators. Just think its easier managed and can look better.
  9. #9
    ROG Enthusiast Array Goggle Eye PC Specs
    Goggle Eye PC Specs
    MotherboardRampage lV Black Edition
    ProcessorI7 4930K
    Memory (part number)F3-17000CL9Q-16GBZH
    Graphics Card #1GTX 780 S.C.
    Graphics Card #2GTX 780 S.C.
    Sound CardOn Board
    MonitorLG Ultra Wide 34 in BenQ 24 IN
    Storage #12 x Samsung Pro 2TBs Each
    Storage #22 x Intel 540 480 GBs Each
    CPU CoolerNH-D14
    CaseCase Labs
    Power SupplyCorsair AX 1500w I
    Keyboard Ducky 908 G2
    Mouse Logitech G3
    Headset Sennheiser HD 650
    Mouse Pad None
    OS 7 Ultimate 64 Bit
    Network RouterNA
    Apr 2011
    63
    Deon correct. A well planned single loop will cool better than a dual loop. Been proven to may times. Looks much cleaner. You do not need to split the radiators between hardware you may have done so to keep the loop short as possible? Shortest possible Loop better. You have room for a D-5 Pump in the floor of the case towards the front. A res will fit on the back of the Case above the PSU in front of the GPUs. Measure for side panel clearances. Un snap the res with tubing attached and drain the system. No drain valves required. Do not attach hardware to the M/Board tray especially if it is removable. Makes it difficult to remove the M/Board tray & Mother board.
    A Recommendation. Take pictures of your system. Load in Microsoft Paint and draw the loop. Figure out the hardware. Post pictures of the loop and ask lots of questions. Start the loop at the center of the loop (CPU) and work out towards the outer edge of the loop. Do not cross any tubing. Fluid direction does not matter. Pump first or not but pump after the res always.
    CaseLabs Magnum 8
    Asus Rampage 4 Black Edition
    I7 4930K 4.5GHz
    Noctua NH D14
    G-Skill Z Series 2133 MHz 16 Gb
    2x GTX 780 S.C.
    PSU Corsair AX 1500 I
    2 x Samsung 850 Pro 2 Tbs Each
    2 x Intel 730 Series 480 GBs Each
    Sound On Board
  10. #10
    Deon017 PC Specs
    OS WIN 10
    Deon017's Avatar
    Aug 2013
    147
    I do fully agree that planning it well is the best advice before you start buying barbs and fittings - I never did the first time and learnt an expensive lesson
