03-01-2015 08:21 AM - last edited on 03-06-2024 03:17 AM by ROGBot
03-01-2015 10:21 AM
04-05-2015 05:48 PM
04-06-2015 05:32 AM
superivansote wrote:
the model you are looking for has the same design as mine therefore be quite similar in the way it works, except for the graphics card I have the gtx 970 and your model have gtx 860m.
the processor is maintained at temperatures of 65 degrees Celsius at the time of playing, if you are using programs this temperatura will be lower than games therefore it will remain cooler, the asus heat dissipation compared to others is one of the best on the market.
acer model you mention is lighter but over time its components begin to deteriorate because it doesnt have a good heat dissipation.
both models are able to work quite fast but with this hacer model and other thin models will have problems with heat in the future
acer is thinner (thin = heat)
asus model is thicker and heavier but I will keep your computer in good condition when you are working or gaming, the weight of this model is around 5kg also its dimensions are bigger than just the size of the 17-inch screen (bigger = heavier = less heat=more life time)
I personally have the asus model g751jt and I'm really happy, I can do many things besides play pc games with the computer
the computer as such is able to give you the feeling of having a desktop computer, but like a portable device
good day
04-06-2015 05:51 AM
04-06-2015 09:49 AM
04-06-2015 10:26 AM
