Questions On 3 way monitors
Bodycount69
Hi I have a Asus G20AJ That I upgrade the GPU to a GTX 980.
I have a Asus PB278Q monitor so this weekend I was out and seen a PB278Q on sale so I picked it up thinking it would be cool for gaming only to find out it would do what I wanted turn out a need 3-Way monitors so my question is can one GTX 980 handle 3 Monitors dose it slow the card down in any way?
I'm in a case where I can only put 1 Double slotted card in it 😞
Thanks for looking and have a great day 🙂
Asus ROG PG348Q Black 34" 3440 x 1440, 100Hz Curved IPS G-Sync 21:9 WQHD Gaming Monitor
2x ASUS GeForce GTX 1080 8GB ROG STRIX OC Edition in SLI
Chino
Level 15
It depends on what you are doing with it. If you're only using 3 monitors for daily work, you shouldn't encounter any problems. But if you're going to game on 3 monitors, the GTX 980 will fall short unless you lower the eye candy.
Bodycount69
Ok Gaming is what I want to do.
Chino
Level 15
You're going to need more than one GTX 980 if you're planning to game on 3 of those monitors in a surround environment.
