motherboard h97 pro gamer plus VGA R9 280x P-3GD5: compatible?
alexei_colorado
Hello, my doubt is if the mother board h97 pro gamer (slots: 1 x PCI Express 3.0 / 2.0 x 16, 1 x PCI Express 2.0 x 16, 2 x PCI express x1, 3 x PCI slots) is compatible with VGA R9 280x? P-3GD5 The slots on the mother board are sufficient for VGA worked properly? Thanks a lot!
Xenocrates
The answer is yes, the card will work with the motherboard. I'd be more concerned about it being able to fit in the case, and if the height would interfer with any other cards you use. If it's the only card in there, it would work just fine.
