G750JS No Fan Setting
ktmn110
Hey guys, I bought a G750JS a couple of months back and I've noticed that I don't have a setting in GPU Tweak to set my fan speed. Does anyone know how to solve this problem?
4 REPLIES 4
navis995
Level 11
You do not have that option. The only way to control fans is to use GPU Tweak 1.0.9 where you can set the max fans to both CPU and GPU. It may not work on your model but it's the only "official" way to do it.
Asus Rog G750JZ
Screen: 1920x1080 17.3'
CPU: Intel® Core™ i7-4700HQ (3.4Ghz @ -70mV)
GPU: GeForce GTX 880M 4GB (OC +125Mhz Core, +600Mhz Memory @ 1.062V)
RAM: Samsung 32GB 1600MHz
Storage #1: Samsung Evo 840 250GB
Storage #2: Samsung Evo 850 500GB
Storage #3: Seagate Barracuda 2TB
Storage #4: Samsung Evo 128GB MicroSD
Would you happen to know if it is safe to have the fans spinning at max while gaming? It has a great effect on temps, so I kinda put them on max speed when reaching 80ºC, instantly cooling gpu to 60ºC in max load. Would this damage something in the long run?
As anything made from anything gets used after some time, your fans aren't an exclusion. BUT unless you're planning on having this laptop for 20 years you should be fine with turning it on maximum when playing games.
Asus Rog G750JZ
ktmn110
Thanks so much for the info
