03-06-2015 08:34 AM - last edited on 03-06-2024 03:26 AM by ROGBot
03-06-2015 08:53 AM
03-06-2015 09:08 AM
odysseas.nemo wrote:
Hello all,
I am trying to setup the fan controller that came with my case (phanteks enthoo primo), but no matter what configuration I try the fans are always stack to max RPM. I RMA the fan controller, but testing at supplier site showed no problems suggesting my motherboard.
Does any of you guys had any expiriance with it?
For reference, I connect the fan controller to the CPU fan header and power it up over the SATA cable (tried any other header as well with the same results).
Thanks!
03-06-2015 02:06 PM
03-06-2015 02:15 PM
Thank you for your suggestions guys.
I have set PWM at the BIOS and have tested with PWM and DC fans.
03-07-2015 01:07 AM
03-06-2015 02:23 PM
03-06-2015 03:22 PM
Hello all,
Thanks!
03-06-2015 05:06 PM
