Results 1 to 6 of 6
Thread: Long Post Beep
    ROG Guru: Green Belt Array drop4205 PC Specs
    drop4205 PC Specs
    Laptop (Model)What are laptops
    MotherboardMaximus XI Formula
    ProcessorI9-9900K
    Memory (part number)Gskill Trident Z F4-3200C14-32GYZR
    Graphics Card #1Nvidia Reference RTX2080TI
    Graphics Card #2ha I wish
    Graphics Card #3ha I wish
    Graphics Card #4ha I wish
    Sound Cardha I wish
    MonitorAsus VN247H-P 23.6"
    Storage #1Samsung970 EVO Plus 1T
    CPU CoolerHeatkiller
    CasePhantex Evolove X
    Power SupplySessonic Prime Titanium 850
    Keyboard ROG Strix Flare
    Mouse ROG Gladius II
    Headset Astro A40
    Mouse Pad Corsair
    OS Windows 10 Home 64 Bit
    Accessory #1 Ek GPU Block
    Accessory #2 EK SE 360 Rad, EK PE 360 Rad
    Accessory #3 EK D5 Vario 140 Pump/Res
    drop4205's Avatar
    Mar 2013
    47
    517
    Long Post Beep
    I just finished my build today (system in sig). I came from a maximus 6 gene and when I hit the power button it was about 3 seconds then the beep from speaker then load windows. On the Rampage it like 6 sec then beep. No big deal if this is normal or not just wondering if there is more going on cause this board has more features. Still rocking the 0706 as I havent been able to see a reason to update the bios. Build went together great. XMP emabled no issues at all.
    Maximus XI Formula, I9-9900k, Phantex Evolove X, Seasonic Titanium 850W, Custom loop PE360+SE360 Rad, G.Skill Trident Z F4-3200C14 32g, Nvidia Reference RTX 2080 TI, Samsung 970 EVO Plus 1Tb, ROG Strix Flare keyboard, ROG Gladius II
    ROG Guru: White Belt Array Radeson PC Specs
    Radeson PC Specs
    MotherboardRampage V Extreme
    ProcessorIntel I7 5960x
    Memory (part number)16 gb 4x4 Corsair Dominator Platinum 2800mhz (CMD16GX4M4A2800C16)
    Graphics Card #1Sapphire Radeon R9 290 (ref) X4
    MonitorToo many to list
    Storage #1Samsung 850 Pro 256gb X4 (RAID0)
    Storage #2Seagate 1tb 7200rpm HDD
    CPU CoolerKoolance 380i CPU Water-Block Custom Loop
    CaseRosewill Blackhawk Ultra
    Power SupplyCorsair AX1500i
    Keyboard Razer Blackwidow Ultimate Stealth
    Mouse Razer Deathadder
    Headset Razer Kraken 7.1
    Mouse Pad Razer Vespula
    OS Windows 10 Pro 64bit
    Dec 2014
    116
    one beep is normal. Also there seems to be about a 5-6 second wait yes, the x99 has a more intensive stress test because of ddr4 ram being more finicky and more features I believe. As long as you are not having problems booting you should be A-ok...
    drop4205 PC Specs
    ProcessorI9-9900K
    Sound Cardha I wish
    Headset Astro A40
    Mouse Pad Corsair
    drop4205's Avatar
    Mar 2013
    47
    517
    thank you for the response. I am very impressed so far with the way the board is performing. I was thinking that it has 2 bios in it thats why. Any reason for me to update the bios to a newer one as I have no issues on this bios yet?
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    If your system is stable, there is no need to update. If you need some of the new functions, then go ahead.
    drop4205 PC Specs
    ProcessorI9-9900K
    Sound Cardha I wish
    Headset Astro A40
    Mouse Pad Corsair
    drop4205's Avatar
    Mar 2013
    47
    517
    On the 1302 bios and finally got a fast boot. Lot better than it was. Last Bios time is 15 to 15.5 now
