Green power lights
wolfy
Hi i have just got 2 x R290 X matrix platinum Cards and i have a couple of questions the power ligts wher you connect the power are green (which is normal) but they do not go off not even when the computer is turned off is this normal?
allso what sort of temps should i be getting BF4 crashes after 30 mins temp is about 75c
ROG MAXIMUS XI FORMULA
CPU: Intel 9900K @4.7 ghz
2 x Corsair Vengeance RGB PRO DDR4-3200
C16 BK DC - 16GB
1 x Aurous 2080Super 8GB
1x 500GB Samsung 980 M.2 NVMe
1x 500GB AData 8200pro M.2NVMe
2 X 500 GB SSD
1000w PSU from corsair
Tower Lian Li PC-O11DW Dynamic
1 x dell 34" curved + 1 x 24"
CPU and Motherboard.
NZXT Kraken X73 RG
4 REPLIES 4
elesde
No idea about the power LEDs since I don't have that card myself, would guess they are maybe running on +5V standby power like some mainboard power indicators do.
As for the temps 75°C sound pretty good actually for 290X in Crossfire, in line with how hot the matrix cards usually get and way below the reference design 290 series.
Are you running BF4 on Mantle by any chance or does the setup crash on other games as well? Last I heard they had some bugs in BF4 on Crossfire + Mantle but apparently they were fixed a few months back (knowing EA they probably built in a few new ones in the meantime :D).
wolfy
I think it is stable I deleted the mantle cache and it seems to have done the trick
C16 BK DC - 16GB
2 X 500 GB SSD
NZXT Kraken X73 RG
X-ROG
Level 15
Lights stay on so if your PC crashes/fails then you can check immediately if a cable came lose etc
75C is good for CF. Do you have a side case fan?
wolfy
thanks for the answer marshall it seems to be running ok temps don't get much over the 75 I maybe will make a profile for BF and other games as icould see that the fans never went over 40 % speed..
C16 BK DC - 16GB
2 X 500 GB SSD
NZXT Kraken X73 RG
