Results 1 to 3 of 3
03-15-2015 06:17 AM #1
- Join Date
- Nov 2013
- Reputation
- 10
- Posts
- 5
Help installing second hard drive [G750jw]
I recently bought a new hard drive. Today I tried installing it and got it into the computer the correct way (as far as I can tell and from the vids I've seen), but it doesn't show up when I boot up my computer and take a look at the drives under "my computer". The hard drive is a samsung seagate SATA2. Is there anything else I have to do to get it installed or to show up? I'm really new to this so any help would be appreciated. Thanks in advance!
03-15-2015 12:10 PM #2
AlbertoBedo PC Specs Motherboard Rampage V Extreme Processor i7 5930K Memory (part number) Corsair Dominator 2666 MHz CMD32GX4M4A2666C15 Graphics Card #1 Asus STRIX GTX 980 Monitor NEC Spectraview PA272w Storage #1 Samsung 850 Pro SSD 256 GB Storage #2 WD Black 1TB CPU Cooler Cooler Master Nepton Case Coller Master HAF Advanced Power Supply Corsair Platinum AX 1200 OS Windows 8.1
- Join Date
- Mar 2015
- Reputation
- 10
- Posts
- 12
Yes, you have to format/init it:
http://www.pcworld.com/article/24898...n-windows.html
03-16-2015 01:42 AM #3
- Join Date
- Nov 2013
- Reputation
- 10
- Posts
- 5
Thanks! I'll see what I can do!
