03-17-2015 03:04 PM - last edited on 03-06-2024 03:21 AM by ROGBot
03-18-2015 10:50 AM
03-19-2015 09:03 AM
hmscott wrote:
After 1.5 years on my G750JH battery, wear level is 8.2%...
03-19-2015 12:31 PM
NitroX wrote:
And how did you manage to do that 😄 ? I'm quite curious to know if the things that I have recommended are indeed true or false. I only have a 3 months experience with this one and I cannot have a strong personal background for this subject.
03-20-2015 08:46 AM
03-20-2015 08:50 AM
03-20-2015 02:56 PM
03-20-2015 03:34 PM
navis995 wrote:
Wear level changing weekly. You HAVE to use battery at least once per week to keep it healthy. I have G750JZ for 6 months now and the battery wear is 4%, yesterday was 5% 2 weeks ago 10% and then again 5%. Its changes depends on the battery usage. If you're using it a lot or just here and there. All in all no worries. As long you use it here and there and not completely discharge it (around 10-15% left) you should have it for 4 years without any problems. Don't bother removing it out when you're doing heavy gaming either because it may just do more harm than good. All in all no battery will last 10 years with no wear what so ever, which may change with carbon based batteries but that is still yet to come 😉
Cherio
03-21-2015 06:21 AM
