Results 1 to 1 of 1
    New ROGer Array
    May 2013
    2
    Project Bordeaux
    So the build is complete, it took 4 solid days to complete.... It's intended as a high end workstation build for photo and video editing.
    Since the LD case didn't have the all of the mounting points for the motherboard, I added them to the motherboard tray of the case. All 4 SSD's are custom mounted. Blue led light used to highlight the entire case and there is white leds to show off the SDD's.
    The specs are as follows:
    LD PC-V7 Reverse Black Red 240/360
    ASUS Z10PE-D8 WS Dual
    2x Intel Xeon E5-2650 V3 2,3 GHz (Haswell-EP) Sockel 2011-V3 - boxed
    Crucial 64GB DDR4 RDIMM
    ASUS GeForce GTX 980 POSEIDON, 4096 MB GDDR5
    4x Samsung 850 PRO Series SSD, SATA 6G - 1 TB
    Seagate Enterprise HDD, SATA 6G, 7200RPM, - 6 TB
    EVGA SuperNOVA 1300 G2 - 1300 Watt PSU
    2x Noctua NH-U12DXi4 CPU-Cooler- 120mm
    6x Aerocool DS Edition Fan, Red - 120mm
    NZXT APERTURE M, 5,25 Cardreader
    Lamptron CW611 Controller
    1x BitFenix Alchemy Connect 30x LED-Strip 60cm - blue
    2x BitFenix Alchemy Connect 6x LED-Strip 12cm - white
    And this was one of the first benchmark runs,
    http://www.3dmark.com/3dm/6210904
    http://www.passmark.com/baselines/V8...id=38052108403
Tags for this Thread
