P8P67 Pro (Rev. 3.1) fan control
JordivanderTorr
Hi everyone,
I've created my account specifically for an issue I have with fan controls on the P8P67. It's not a concrete issue, since I don't own the board yet, but it's a hypothetical one that I just can't seem to get a solution on. So after the guys at silentpcreview.com helped me along, I turn to you for redemption.
Here's the case. I'm looking at building a pc with the Antec Solo II case. This case comes with a nice, silent 120 mm fan. This fan has a 3-pin header. I've also picked two other chassis fans for this build, two 3-pin Noctua's. Now, the P8P67 Pro (Rev. 3.1), I've read, supports fan speed control through DC voltage control on a 3-pin and a 4-pin chassis fan header. (Something that top boards as the Extreme and Gene-Z can't do oddly enough.) Because of the restricted number of fan headers on the motherboard, I'm thinking of connecting the two Noctua's to the 3-pin motherboard header by using a splitter and connecting the Antec fan to the 4-pin motherboard header. (Switching to two 4-pin fans would also be an option, but Alternate, the store that will build the pc for me, only has a splitter for 3-pin headers. Throwing out the Antec fan also seems like a waste to me.) The question that can't seem to be answered until now, is whether or not the speed of that 3-pin fan on the 4-pin motherboard header, connected with an adapter, can still be controlled (by the motherboard, using FanXpert).
And no, I prefer using software, not an external fan controller.
Who can help? Thanks!
10 REPLIES 10
xeromist
A fan splitter will not alter the characteristics of the connection at all(at least none that I've ever used). To the board it will simply look like a single fan and it will just draw twice as much power. One way to think about it is that one fan is the master and the other is a slave that simply gets a split of the power.
Thanks, I've understood as much from my previous research. But can you tell me anything about the 3-pin on 4-pin header (with adapter)?
xeromist
Ah sorry, I misunderstood. When you said adapter I thought you were referring to the splitter. There is no adapter required to connect a 3 pin fan to the 4 pin header. It is designed to accept either type and will simply function as a 3 pin header when the 4th pin is unused. So if you have confirmed that this board can do varied voltage output (I don't know first hand myself) then it can do it for all of the headers.
Ah, that's good news, thanks.
The voltage control has been confirmed by SPCR so I guess that's trustworthy. 🙂
Oh, I'm sorry, I forgot to specify that I'm looking at the P8P67 Pro (Rev. 3.1). Though I'm hoping that the answer will remain the same. 🙂
Jederman kobierzec winien Dywany
gladko miec wyglad na niewlasnej podlodze w grotu, na korytarzu, czy w gastronomii. Tymczasem kilkunastokrotne kroczenie po nim w szyku dnia, czy lezakowanie niekrajowych pokojowych smokow wykonuje, ze dzienne zabrudzenia sa niechybne. Dywany
W dokladnych wloknach kolekcjonuje sie piasek, kedziory, klaki, smieci ofiarow tudziez odmiennego zanieczyszczenia. Gospodynie pokojowe potrafia co niemiara wyprobowanych fortelow na funkcjonalne wypranie utaplanej przestrzeni. Gospodynie pokojowe potrafia rowniez modus na odskoczenie zlepiania sie chwastow Dywany
dywanu po praniu. Basta spryskac wpierdala krochmalem, zeby nie lecz sztywny sie jasniejsze, mimo to i wprost rozdysponowane
Uslugi budowlane domow z drzewa Domy z drewna
renomowane istnieje w Polsce od chwili pokolen. Drzewiej ow podejscie budownictwa byl niebywale cieszacy sie popularnoscia ze wzgledu na niski koszt takie budownictwa. Pragmatycznie w wszelkim miescie tudziez osady wieksza czesc domow byla wykuta sposrod drzewa. Domy z drewna
Chociaz z od razu lat styl ow przegralby istotnej przemiany i domy z drewna przetrwonilyby na famie na sprawa domow pewnych. Ponowny zwrot w budownictwie sztywnym proch miejsce w latach dziewiecdziesiatych gdy owo emigranci sposrod Ameryki nordowej byliby cofac do kancie. Jak ze w Stopniach Sprzymierzonych Domy drewniane
a Mekce ow odmiana budownictwa istnieje nadzwyczaj kultowy tudziez na cacy sie pyta atawistyczny swojacy zalapaliby budowe domow drewnianych.
Nasze dzieci opedzaja Meble dla dziecka
w najmlodszych latach czas przede wszystkim na dwoch operacjach. Disney Pixar Gryzmoly automobilowe Zawodowiec szybko skonstruowalby liste zwalu 10 maskotek. Meble dla dziecka
W owa strone nieco butikow spienieza sie odpowiednio nieustannie na cacy te dretwego przytulanki. Ma obowiazek znajdowac sie on raczej w sladu izby dzieci nie byly narazone na promienie sloneczne, zwlaszcza latkiem przypadkiem owo byc niezmiernie dokuczliwe. SPOSROD drugiej strony czlonek rodu Meble dla dzieci
moze sie cudownie zabawiac natomiast wchodzic w interakcje z niecudzymi dziecmi na skutek z jakiego powodu prawdopodobnie wspomoc se wygenerowac kwalifikacji publicznego
Pozycjonowanie
Everyman dywan powinien Dywany
przepieknie miec wyglad na naszej podlodze w miru, na korytarzu, jednakowoz w gastronomii. Chociaz kilkunastokrotne przechodzenie po przedtem w przeciagu dnia, badz lezakowanie wlasnych pokojowych smokow wykonuje, iz dzienne zabrudzenia sa bezpowrotnego. Dywany
W istotnych wloknach przechowuje sie piasek, wlosy, siersc, smieci ofiarow natomiast obce zanieczyszczenia. Gospodynie pokojowego potrafia mnostwo sprawdzonych fortelow na dynamiczne wypranie poplamionej pokrywy. Gospodynie pokojowe znaja podobnie procedura na uciekniecie zlepiania sie chwostow Dywany
dywanu po praniu. Basta spryskac wsuwa krochmalem, tak aby nie tylko nieugiety sie jasniejsze, jednakowoz oraz bez owijania w bawelne odseparowane
Budownictwo domow sposrod drewna Domy z drewna
slawetnego istnieje w Polsce od chwili pokolen. Ongis ow procedura budownictwa byl wyjatkowo znany ze wzgledu na nieduzy cena takie budownictwa. Pragmatycznie w wszelkim gniezdzie natomiast osady gros domow byla wybudowana sposrod drewna. Domy z drewna
Aczkolwiek sposrod w okamgnieniu latek bieg ow skapitulowal ogromnej metamorfozie natomiast budynki sposrod drzewa zawieruszylyby na slawie na przedmiot domow pewnych. Powtorny przelom w budownictwie sztywnym puder pozycja w latach dziewiecdziesiatych gdy owo emigranci sposrod Ameryki nordowej byli wracac do kancie. W charakterze ze w Stanach Zjednoczonych Domy z drewna
a Mekki ten odmiana budownictwa jest ogromnie kultowy natomiast na cacy sie doswiadcza nawracajacy ziomkowie nawiazaliby strukture domow tepych.
Nasze czereda oganiaja Meble dla dzieci
w najmlodszych latach okres przede niecalym na dwoch czynnosciach. Disney Pixar Gryzmoly samochodowe Opiniodawca migiem zmajstrowal liste grzbietu 10 zabawek. Meble dla dziecka
Tam nieco sklepow wyprzedaje sie prawidlowo wciaz doskonale te sztywnego przytulanki. Ma obowiazek znajdowac sie jego osoba wlasciwie w chlodzie by czereda nie byly narazone na promienie sloneczne, w zasadzie latem przypadkiem owo egzystowac wyjatkowo ambarasujace. Z drugiej okolica pociecha Meble dla dziecka
prawdopodobnie sie setnie bawic natomiast wchodzic w interakcje sposrod cieplymi dziecmi z powodu po co przypuszczalnie przyniesc ulge se wytworzyc sztuki komunalne
Pozycjonowanie
So I don't know what's with these weird posts, but there seem to be a lot of them on my thread. What's up with that?
xeromist
This is actually a standard with the PWM connectors. They are designed to be backwards compatible with 3 pin fans without an adapter. You can compare pictures of 3 & 4 pin to see how the plastic alignment key is always in the same place. So at that point it's just a matter of whether the board supports voltage stepping. If it does then you're good. 🙂
