So my system was working perfectly fine. I installed a waterblock on my GPU and got a bad seat, and the system was shutting down every time the GPU would overheat. I removed it, reseated it, reinstalled it, but now when I try to power on my system doesn't boot the BIOS, doesn't output any video, the Q-Code stalls on FF, and the CPU-LED is solid red. Pumps RPM and PWM leads are plugged into CPU fan port, and the V+ and GND are plugged into PSUs Molex so that's not the issue. Tried removing the HDD, and USB devices to get it to boot to BIOS, still nothing.
Absolutely nothing about the system has changed. Anyone got any ideas on what might be wrong?
System is:
Motherboard: Crosshair V Fomrula-Z
CPU: FX-8350
GPU: R9 290x
RAM: 4*4GB
PSU: 1000Watt OCZ
Any help would be appreciated, I'm at a loss since it was working fine (other than the overheating) Then decided to stop.
-Z
