Results 1 to 10 of 31
04-05-2015 02:02 PM #1
- Join Date
- Mar 2014
- Reputation
- 10
- Posts
- 56
caught fire - ASUS Crosshair V formula - Z
To start I just wanna stress how hit and miss these boards can be. I have always thought of ASUS of having high standards (other than their RMA call centers negligence and lack of quality reps who understand tech problems) and great quality products. I have now had 3 of these boards have issues. (just check my previous posts).
So now to the story of the motherboard that caught fire on its PCB....
So under a stress test and even down clocking my FX8350 voltage on a previosly stable 4.7Ghz overclock to get better temps my motherboard PCB went up in flames after only 3 minutes in prime95 with core temps reaching only 60? and the socket only 70?. I was about to turn off prime95 even but my computer shut down to prevent damage but then immediately turned right back on and my motherboard PCB near the VRM mosfets/chockes went up in flames. Other parts including CPU, RAM look fine.
I am not sure what might have caused this. I did tweak some power management settings in BIOS to prevent voltage droop and adjusted the HT link speed to its safe max - 2600mhz. My CPU voltage was lowered from 1.46 to 1.45v. Then after testing it, the smell came on and then all he'll broke loose on the motherboard PCB....and I thought PCBs were coated with fire-retardants. Apparently not this one.
Note: CPU and NB were cooled by EK waterblocks and had been for some time.
Note 2: hadn't stressed tested system after getting replacement NZXT Hale 90 ver.2 PSU 1200watts (gold rated)...it had never given me problems before so I'm not sure this could be the culprit.
Note 3: this is the 3rd ASUS CROSSHAIR V formula- Z motherboard I have recieved from ASUS...all having previously had faulty DIMMs or other problems.
I have contacted both AMD and ASUS for RMA for advice but I'd thought I'd let the hardware communities such as yourselves be aware of stuff like this.
MB: Crosshair V formula-Z
CPU: AMD FX8350 (8-core) @ 4.7Ghz
RAM: Corsair Dominator Platinum (8x2) 16gb
GPU: AMD Firepro W8100 (8GB workstation card)
cooling: custom water loop ,Ocool Nexxus U60 420 triple radiator,
Swiftech MCP655-B pump, Bitspower Compression fittings
HDD: OCZ OCZ "Vector" 256gb
PSU: NZX Hale90 v.2 1200W
04-05-2015 02:02 PM #2
- Join Date
- Mar 2014
- Reputation
- 10
- Posts
- 56
this conversation is also going on TomsHardware
04-05-2015 05:54 PM #3
did you use the extra 4pin power on the motherboard? ( and no not the molex )
04-05-2015 05:54 PM #4
04-05-2015 11:35 PM #5
- Join Date
- Mar 2014
- Reputation
- 10
- Posts
- 56
04-05-2015 11:35 PM #6
- Join Date
- Mar 2014
- Reputation
- 10
- Posts
- 56
04-06-2015 02:08 AM #7
Esmea PC Specs Motherboard Crosshair VII Hero (Wi-Fi) Processor AMD Ryzen 3900X Memory (part number) 64GB G.Skill TridentZ RGB 4x16GB F4-3000C14Q-64GTZR Graphics Card #1 ASUS R9 390X DC2OC Monitor 2x Monoprice 2560x1440 Freesync 240Hz Storage #1 Samsung 960 Pro M.2 500GB Storage #2 4TB WD Black CPU Cooler AMD Wraith Prism Case Thermaltake Core V71 Power Supply SeaSonic 1050W PlatinumPlus Keyboard Logitech G510s Mouse Logitech G903 Headset Monoprice Wireless BT Mouse Pad Logitech PowerPlay Headset/Speakers Creative 2.1 OS Win10 Pro Network Router ASUS ROG Rapture GT-AC5300
- Join Date
- Mar 2015
- Reputation
- 10
- Posts
- 12
Wow, those pictures sure bring back memories of when I had the same thing happen on a motherboard in 1998. Mine was a burnout with the sound card wiring, though.
Sometimes things just don't work out in manufacturing; hence why warranties address "manufacturing defects." Even the best brands have runts that slip through.
04-06-2015 06:01 AM #8
- Join Date
- Mar 2014
- Reputation
- 10
- Posts
- 56
04-06-2015 07:16 AM #9
04-06-2015 09:31 AM #10
- Join Date
- Mar 2014
- Reputation
- 10
- Posts
- 56
yes, i used the 8-pin as well.
