Results 1 to 2 of 2
    ROG Enthusiast Array
    Apr 2015
    28
    RIVE-CPU strap issues
    Hi guys, I am fairly new to overclocking on the X79 Chipset. I am doing something a little different here.
    RIVE
    Xeon E5 1620
    I am Multiplier limited with this chip as it is not an unlocked chip, This only will net me a 4.3ghz overclock using just the Multi(100x43). This is achieved with 1.285 Vcore.
    What I am now doing is Using the 125 Strap and a Multi of 37 (125x37) 4625mhz. CPU appears to be stable so far giving it 1.38v in the Bios using A load Line of High.
    The issue that I am having though is with the strap of 125 I am getting Nvidia Video driver crashes(Thought the strap was supposed to stop that).
    Is there something else voltage wise I need to be changing when using the 125 strap? If I try to play a game I just get a black screen until I alt tab out with the warning of the driver crashing.
    Any tips are appreciated.
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,718
    I'm guessing *guessing* that you might need to bump your VCCIO and/or VCCSA voltages to help stabilize the PCIe controller integrated within the Xeon proc. This site might help.
