Results 1 to 7 of 7
11-19-2011 03:37 PM #1sleeping pandaGuest
need help with ASUS ROG OC station. display wont turn on
I have a ROG OC station i bought new. it wont turn on. i have the Molex power hooked up, and the ROG cable that plugs into the header on the motherboard.
A little blue light is on in the back of the oc station next to the #1 fan header.
but it wont turn on, and the oc station tool on my pc says its disconnected.
my system specs are:
AMD phenom 1100t processor
CH IV-E mobo 0504 BIOS, and ive tried the 2002 bios
GTX 580 matrix platinum gpu
windows 7 64 bit
8gb g.skil flare ram
ocz vertex 3 120gb ssd
01-29-2012 02:08 PM #2
- Join Date
- Jan 2012
- Reputation
- 10
- Posts
- 8
i know its an old message but have you had any luck since??
02-06-2012 08:22 AM #3
I have oc station and that board I may be able to help with issues.....
Praetor
» i7 990X 3101A239
» Asus Rampage III Black Edition
» Asus GTX 470 & 570 Tri-SLI or Three Sapphire 5850's CFX
» 6GB Corsair Dominator GT TR3X6G1866C7GTF
» Corsiar Force Series 180GB
» CORSAIR Professional Series AX1200 1200W
» Microcool Banchetto 101
Defiant
» G74SX » 16GB ram » Corsiar Force Series 180GB » 750GB Seagate » Blu-ray
02-14-2012 03:10 PM #4
- Join Date
- Feb 2012
- Reputation
- 10
- Posts
- 10
I have always had problems with the OC station on my CHIV-E, asus support worse than useless to the point they insisted I was having a hardware malfunction and should have the OC station replaced, which I did... same problem persists. Some people on other forums with the same issue noticed that NVIDIA cards seem to cause various problems, what graphics do you have installed?
oops, sorry noticed you DO have an Nvidia Card... do you have anything you could swap it out with to test?Last edited by Terramonkey; 02-14-2012 at 03:11 PM. Reason: update
02-27-2012 04:22 AM #5
_ PC Specs Laptop (Model) G46VW Motherboard Rampage IV Gene Processor Intel Core i7-3930K Memory (part number) Corsair Dominator Platinum 32GB (CMD32GX3M4A2133C9) Graphics Card #1 ROG Matrix GTX 780 Ti Sound Card ROG SupremeFX III Monitor ASUS VG248QE with GSync mod Storage #1 Plextor PX-M2 SSD 120GB Storage #2 G.Skill Phoenix Blade 480GB PCIe SSD CPU Cooler Cooler Master Seidon 240M Case Cooler Master HAF-X Power Supply Seasonic X-750 Keyboard Corsair K90 Mouse ROG Gladius Headset ROG Orion OS Windows 8.1 Update 1 Network Router ASUS RT-AC66U
- Join Date
- Dec 2011
- Reputation
- 119
- Posts
- 5,750
There was new drivers out on 24th Feb - have you tried?
03-04-2012 12:49 PM #6
- Join Date
- Feb 2012
- Reputation
- 10
- Posts
- 10
Yup, seems to have done the trick, for me anyway!
Now just need Asus to sort out THIS issue with the AI Suite ii package!
lol
EDIT - seems to have reverted back to not working again after a reboot... oh well!Last edited by Terramonkey; 03-05-2012 at 12:12 PM. Reason: Update
03-14-2012 10:30 AM #7
If the programme worked before the reboot it means that there is a conflict with some other software. If the issue is still a problem post back and we will work through it.
Similar Threads
ASUS R.O.G OC STATION
By Jason Coates in forum Case Modding & PC BuildsReplies: 9Last Post: 11-03-2016, 01:51 PM -
ASUS ROG OC STATION
By Jason Coates in forum Case Modding & PC BuildsReplies: 8Last Post: 11-01-2016, 05:11 AM -
NEW G74SX WONT TURN ON - PLEASE HELP!!!
By PHorst in forum ROG Gaming NotebooksReplies: 19Last Post: 11-07-2011, 07:19 PM -
BRAND NEW G74-SX wont turn on
By dralogh in forum ROG Gaming NotebooksReplies: 6Last Post: 10-02-2011, 04:11 PM -
Max4 Gene-z Bios (0605) wont display GPU's in PCIe slots
By yobrevar in forum Other Series MotherboardsReplies: 3Last Post: 09-13-2011, 05:14 AM
