Results 1 to 6 of 6
Thread: Rockcrawler X99
04-23-2015 07:34 PM #1
- Join Date
- Sep 2012
- Reputation
- 10
- Posts
- 47
Rockcrawler X99 (Finished)
Hey everyone,
I'm back with a new build. I'm making a companion for the Sabranco humvee. It will be a fast build as it needs to be finished by 22nd of May. As soon as it is done it will be joining the Humvee at Computex 2015.
As parts arrive i will let you know what the specs will be.
But i want to give a huge thank you to Corsair Johan and the people over at Asus (won't name you but you know who you are) for believing in this project.
I got myself a GoPro camera and will be doing a complete time lapse video of the entire build. I hope to add every bit separately as the build moves forward
The concept. A very rough render of what it will look like. Have made some small changes but nothing too big.
The Truck at Asus HQ
First step to drill some holes in the 6mm aluminum sheet so i can fasten it on the bed of the mill.
Wish i had made my mill a bit bigger. Sheet fastened
Ready to roll
Turned out pretty could, some tiny marks on the alu but will be easy to sand away
Over to the acrylic
Next update in a couple of days,
AlexLast edited by ace_finland; 06-01-2015 at 01:21 PM.
Inverted 600T - OCN Mod of the month July 2012
CM Test Bench V2 - Cooler master mod competition 3rd prize
Rig of The month December - Guru3D
Nice articles of the test bench:Here and here
04-24-2015 10:09 AM #2
_ PC Specs Laptop (Model) G46VW Motherboard Rampage IV Gene Processor Intel Core i7-3930K Memory (part number) Corsair Dominator Platinum 32GB (CMD32GX3M4A2133C9) Graphics Card #1 ROG Matrix GTX 780 Ti Sound Card ROG SupremeFX III Monitor ASUS VG248QE with GSync mod Storage #1 Plextor PX-M2 SSD 120GB Storage #2 G.Skill Phoenix Blade 480GB PCIe SSD CPU Cooler Cooler Master Seidon 240M Case Cooler Master HAF-X Power Supply Seasonic X-750 Keyboard Corsair K90 Mouse ROG Gladius Headset ROG Orion OS Windows 8.1 Update 1 Network Router ASUS RT-AC66U
- Join Date
- Dec 2011
- Reputation
- 119
- Posts
- 5,750
Ahhh and there's my social media calendar in the background! :P
Are you going to use its lights?
04-29-2015 01:47 PM #3
- Join Date
- Sep 2012
- Reputation
- 10
- Posts
- 47
04-30-2015 03:32 PM #4
- Join Date
- Sep 2012
- Reputation
- 10
- Posts
- 47
Back with another update,
Hardware for the mod:
- X99 Sabranco motherboard
- Intel I7 5960X
- Titan black
- 8 x 8Gb DDR4 2400Mhz Dominator Platinum Ram
- H80i GT watercooler
- Neutron GTX 240GB SSD
- SP120 PWM Quiet fans
- RM 650 PSU
-Corsair sleeved cable kit
First some hardware pics (Sorry for the bad photos, have great camera but not very good at using it)
Think most of the pics speak for themselves but i have to say i really like the corsair water cooler.
Last but not least, def my favorite ram! (It just arrived so that's why its not in the first picture)
On to some modding!
Assembled all the pieces i milled and did a quick test to see if even the motherboard would fit
Motherboard plate
The mill was too small so had to mill it and turn it around and mill again.
Someone did a great job gluing this together, decided it was safer to cut it rather than trying to pry it apart
Made som support bars for the underside of the truck bed, just for show
All assembled
A quick test fit
After the quick test fit i wasn't very happy. The overhang was just too much and it did not look like it was meant to be there. So i decided to make some small changes. Stripping everything off.
Decided to cut the frame and extend it with 50mm.
Milled some brackets that mounts flush with the frame
Much better
Everything is still very rough but want to be sure everything is right before i start cleaning up all the parts.
Next update in a few days!Inverted 600T - OCN Mod of the month July 2012
05-09-2015 11:53 AM #5
- Join Date
- May 2015
- Reputation
- 10
- Posts
- 2
Mold removal in Delaware
06-01-2015 01:20 PM #6
- Join Date
- Sep 2012
- Reputation
- 10
- Posts
- 47
Back with another update!
Deadline got shortened a bit so i didn't have time to do any updates, but on the upside i can finish the build log now.
After trying a quick assembly i realized that the suspension and tires were too soft. I filled the "hollow" tires with some stiff foam and upgraded the springs with some "heavy" duty ones i found in the shops.
Now it sits straight and no flat tires.
Made a bracket for the PSU, a bit rough looking but cleaning all bits at once when i know everything fits.
Time to make the PSU shroud/Radiator holder
Milled some slots and some grooves for easier bending
A bit of bending
Turned out pretty good
Next up is to drill holes and tap the sides of the aluminum frame. Decided to make a template of lexan so i could drill all holes quickly and get them perfectly in the middle.
After a lot of cleaning it was time to powder coat all the aluminum. Just love the black texture on the parts.
Cabin painted (sorry for the crappy photo)
Let the assembly begin!
Sanded the acrylic with 1200grit paper. Didn't want it completely see through and i didn't wanna see the scratches, turned out ok
Tail lights installed
IO panel test fit
Forgot to take pictures on painting the gpu but here it is in all its glory (titan black)
I found three M3 holes on the back of the GPU, so it was easy to make a bracket for it so it hovers over the motherboard.
Sneaky gf
Not much left now
Everything fits nicely, Only one dvi port that's not really usable. I only ever use one monitor so not really an issue. I didn't wanna raise the whole structure just for the dvi port.
Lights working
Running nice and cool
Had to take it outside
If you happen to be at Computex be sure to check it out over at Asus!
Thx for looking!Inverted 600T - OCN Mod of the month July 2012
