Parvum Project Red & Black
paultoke
Hi
Just finished a build and thought I would share some pics with you.
MB: Asus Maximus VII Impact mini-ITX ROG motherboard
VGA: Asus GTX980 Ref
6 REPLIES 6
drop4205
Level 12
looks nice. not to sure but the liquid color but I do like the way you have it all set up. I have been thinking of a mini itx build. How are the Parvum cases?
Maximus XI Formula, I9-9900k, Phantex Evolove X, Seasonic Titanium 850W, Custom loop PE360+SE360 Rad, G.Skill Trident Z F4-3200C14 32g, Nvidia Reference RTX 2080 TI, Samsung 970 EVO Plus 1Tb, Windows 11
I'm not sure what colour to use either but a neutral colour to start with is easier to change without to much flushing.
The best thing about a Parvum case is you can get them to custom make cases panels etc.
Also being modular they are easier to work with when installing parts in confined spaces.
kkn
Level 14
do not use that perl liquid ( aurora if its that your using ) too long or it MAY clogg up the system.
its is only made for show of systems for a short time of use.
http://www.mayhems.co.uk/mayhems/index.php/guides/mayhems-aurora-guide
Thanks for the info but its ok as I'm using aurora 2 and it is only temporary, only used it for the photos and video I did. I have used it in other build with no issues, but I agree it is only a short term coolant.
chrsplmr
Level 18
Pure Art .. ty. .c.
paultoke
Made some changes to pipework and coolant colour.
