Graphics Card Comparison help.
Lawlypops
I found 3 GPUs that seem to be cheaper than my currently chosen one for my build, and i want to confirm if they truly are.
Original:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150705&cm_re=xfx_r9_280-_-14-150-705-_-Prod...
1st New:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127843&cm_re=MSI_GTX_960-_-14-127-843-_-Pro...
2nd New:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127844&cm_re=MSI_GTX_960-_-14-127-844-_-Pro...
3rd New:
--(Newegg) http://www.newegg.com/Product/Product.aspx?Item=N82E16814127860&cm_re=MSI_GTX_960-_-14-127-860-_-Pro...
--(Amazon) http://www.amazon.com/MSI-GTX-960-GAMING-4G/dp/B00V4HY522/ref=sr_1_3?s=pc&ie=UTF8&qid=1430168962&sr=...
The 3rd is the same as the 1st but with 4GB instead of 2
Here is my Build in case you need it. (I am currently buying everything. The only things i have bought so far is the Case, the HDD, and the SSD)
Motherboard - Asus Crosshair V Formula-Z
GPU - XFX Black Edition Double D R9-280A-TDBD
PSU - Rosewill Photon-1200
Monitor - ASUS VX VX248H 24-Inch Monitor
Keyboard - Razer BlackWidow Chroma
CPU - AMD FX-Series 8-Core Black Edition
RAM - G.SKILL Trident X Series 16GB DDR3 2400
Case - ThermalTake Overseer RX-I
HDD - WD Black 1TB 7200 RPM
SSD - Samsung 850 EVO 120GB
Korth
Level 14
It looks like you're willing to spend up to ~USD$240. And, I suspect from your choices, you prefer faster factory overclocks.
I would go with an R9-280X, it will certainly outperform an R9-280 (it has more processing power and is a little faster in every way, with or without overclocking). It will generally outperform a GTX 960 (although some games are better optimized for the things - mostly PhysX - that NVidia GPUs do a little better, so you might want to check online benchmark results for these cards on the particular games you play).
Another good choice is an R9-285. Newer technologies, a little less of this and more of that, but it benches almost exactly equivalent to an R9-280X in terms of actual performance/fps.
The best http://www.newegg.com/Product/Product.aspx?Item=N82E16814202137&cm_re=r9_280x-_-14-202-137-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125726&cm_re=r9_280x-_-14-125-726-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127839&cm_re=r9_285-_-14-127-839-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125679&cm_re=r9_285-_-14-125-679-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150721&cm_re=r9_285-_-14-150-721-_-Product
[/Korth]
Antronman
The R9 280 is never worth buying.
The R9 285 is better, the 280x is better.
Don't buy the R9 280, whatever you do.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
Newegg has a Sapphire Tri-x 290 $249.99 after rebate. That will keep you going for along time
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202143
