Page 3 of 9 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 82
  1. #21
    ROG Guru: White Belt Array Char82 PC Specs
    Char82 PC Specs
    Laptop (Model)Macbook :(
    MotherboardASUS Maximus VI Extreme Z87
    ProcessorIntel Core-i7-4790k OC: 4.8GHz
    Memory (part number)CORSAIR Dominator Platinum 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900)
    Graphics Card #1Nvidia GTX 980 4-Way SLI
    Graphics Card #2Nvidia GTX 980 4-Way SLI
    Graphics Card #3Nvidia GTX 980 4-Way SLI
    Graphics Card #4Nvidia GTX 980 4-Way SLI
    Storage #1Samsung EVO 850 120GB
    Storage #2WD Black 2TB 7200RPM
    CPU CoolerCORSAIR H100i
    CaseNZXT Phantom Full ATX
    Power SupplyCORSAIR AX1200i
    Keyboard Razer BlackWidow Chroma
    Mouse Razer Mamba
    Headset ASTRO A50
    Mouse Pad Razer Kabuto
    OS Windows 7 Pro
    Apr 2015
    91
    Quote Originally Posted by Nate152 View Post
    That should work good, it has good reviews from amazon.
    http://www.amazon.com/Antec-Diamond-...ct_top?ie=UTF8
    EDIT: In fact I have a tube of that and it works good, I have my cpu at 5.0GHz but I have a better cooler too.
    Attachment 48677
    I drove like an A-hole to make time before they closed 5 minutes ago, but I have acquired the thermal compound!
  2. #22
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,357
    yeah your temps are way too high my friend.
    When you get the thermal compound, clean the cpu and h100i waterblock with a few drops of rubbing alcohol on a klenex or piece toilet paper, don't use paper towels as they are too abrasive.
    After you get it all cleaned off, put a dab about the size of a pea in the center of the cpu and spread it evenly over the entire cpu with a credit card or drivers license. it is important it is spread evenly over the entire cpu. Then install the water block starting at one corner then go diagonal to the next corner, tighten all 4 screws until it is snug, do not over tighten.
    After doing this run the test again like you did, you should have much better temps.
  3. #23
    Char82 PC Specs
    Mouse Razer Mamba
    Headset ASTRO A50
    OS Windows 7 Pro
    Apr 2015
    91
    WOW. Much Much Much better Temps. I noticed when I removed the block that only 1 side of the cpu had the thermal paste on it. Must have not tightened the block down evenly when I first built.
    Happy to report:
    73 74 70 62
  4. #24
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    WOW you're fast and yes WAAAY better temps, now we can overclock your cpu !
    All right let's see how good of a 4790k intel sent you.
    Go into the bios and on the extreme tweaker tab set the ai overclock tuner to XMP, this will automatically set your ram to its rated speed timings and voltage.
    Sync all are cores and set the cpu core ratio to 47 and the cpu core voltage to 1.30v F10 and Enter to save and exit.
    Run the test like you did and post your temps for me please.
  5. #25
    Char82 PC Specs
    Mouse Razer Mamba
    Headset ASTRO A50
    OS Windows 7 Pro
    Apr 2015
    91
    Should I do the full 15 minutes?
    Currently testing...
  6. #26
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    well it would be good to but if it's stable after 5 minutes you can stop it if you like, this will save some time.
  7. #27
    Char82 PC Specs
    Mouse Razer Mamba
    Headset ASTRO A50
    OS Windows 7 Pro
    Apr 2015
    91
    Alright!
    Results:
    5m ~ 1.312v
    87 90 84 76
  8. #28
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    OK that's not too bad
    Go back into the bios and raise the cpu core ratio to 48 and F10 and Enter
    Run the test again to see if you are still stable.
  9. #29
    Char82 PC Specs
    Mouse Razer Mamba
    Headset ASTRO A50
    OS Windows 7 Pro
    Apr 2015
    91
    Well, I Blue Screened...
  10. #30
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    All right try the cpu core voltage at 1.32v if it still blue screens try 1.33v
Tags for this Thread
