Results 1 to 7 of 7
    ROG Guru: Green Belt Array Avenger411 PC Specs
    Avenger411 PC Specs
    MotherboardAsus Rampage V Extreme
    ProcessorIntel 5930K@4.3Ghz
    Memory (part number)G-Skills DDR4-3200 (16-16-16-36-1T) 1.375v
    Graphics Card #1EVGA Titan X w/ 980 Hybrid AiO Liquid Cooler
    MonitorAsus RoG Swift PG278Q
    Storage #1OCZ RD400A (Windows)
    Storage #2Samsung 950 Pro (Gaming)
    CPU CoolerCorsair H100i
    CaseCorsair 780T
    Power SupplyAntec HCP-1000w Platinum
    Keyboard Corsair K70 Cherry-Mx Brown
    Mouse Logitech G502 Proteus Core
    Headset Roccat 5.1 True Surround Digital
    Mouse Pad Razer Vespula
    Headset/Speakers Logitech Z906 5.1 Surround
    OS Windows 10 Pro
    Network RouterNetgear Nighthawk AC1900
    Accessory #1 Iphone 6S 64gb
    Accessory #2 Brainwave Headset Stand
    Accessory #3 Microsoft Xbox360 Pc Controller
    Oct 2014
    33
    617
    Fan Header Question
    Hey
    Can the CPU_OPT be used as a normal fan connector ? I'm looking to putting more fans and this one would be ultra handy. I don't like having to resort to add-on cards for fan connections etc.
    thanks
    Max
    Cpu : Intel 5930K@4.25ghz@1.2v / Cache @4.25ghz@1.20v
    Cpu Cooler : Corsair H100i
    Case : Corsair 780T
    Memory : G.Skills 32GB DDR4-3200mhz CAS 15-15-15-35-1T@1.370v
    Motherboard : Asus Rampage V Extreme (BIOS 3504)
    M2 : Samsung 950 Pro NVME 512gb (Gaming)
    M2 : SSD1 : OCZ RD400A 128gb (windows)
    SSD1 : Crucial MX100 512gb (data)
    Gfx : EVGA Titan X w/ 980 Hybrid Cooling AiO Liquid Cooler
    PSU : Antec HCP-1000W
    Monitor : Asus RoG Swift
    ROG Guru: Yellow Belt Array Deon017 PC Specs
    Deon017 PC Specs
    MotherboardASUS Rampage IV Extreme Black Motherboard
    ProcessorIntel Core i7 4960X Extreme Edition
    Memory (part number)Corsair Vengeance Pro CMY32GX3M4A2133C11 32GB
    Graphics Card #1Asus Poseidon GTX 980Ti
    MonitorAsus Rog Swift 27" 3D Monitor
    Storage #1ASUS RAIDR Express 240GB PCI-E SSD
    Storage #2HDD: Intel 520S 240GB SSD
    CPU CoolerEK Supremacy Elite CPU Waterblock for Intel 2011
    CaseCorsair Obsidian 900D Super Tower Case
    Power SupplyCorsair AX1200i Digital ATX Modular Power Supply
    Keyboard Logitech G19s Gaming Keyboard
    Mouse Asus ROG Gladius
    OS WIN 10
    Network RouterAsus RT-AC3200
    Deon017's Avatar
    Aug 2013
    147
    Yes- I use mine as just that - you can run your fans directly from your PSU, but then you don't have control of them
    Avenger411 PC Specs
    CaseCorsair 780T
    OS Windows 10 Pro
    Oct 2014
    33
    617
    Quote Originally Posted by Deon017 View Post
    Hey
    "run fans directly from psu" care to explain ? i don't see how i can plug a 3pin fan header into my psu --____--. You got my curiosity spiked.
    Max
    Case : Corsair 780T
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,254
    Some heatsinks come with two fans. So apart from having the CPU_FAN header, ASUS also gives you the CPU_OPT fan to connect the extra one. That is also why the settings for CPU_FAN is mirrored off to the CPU_OPT header.
    To connect your fans directly to the PSU, you'd need a 3 pin fan to molex adapter.
    Avenger411 PC Specs
    CaseCorsair 780T
    OS Windows 10 Pro
    Oct 2014
    33
    617
    Hey
    Okay i see. Since i'm using a h100i, my cpu fan's setting is "full speed in q-fan control" so whenever i will plug a fan in the cpu_opt, it will be full speed straight away. Which i want actually so i don't mind. Although, could i use a different settings on the cpu_opt regadless of the mirroring ?
    Max
    Case : Corsair 780T
    Oct 2012
    339
    15,254
    Nope. The CPU_OPT header will always use the same setting you've chosen for the CPU_FAN header.
  7. #7
    Avenger411 PC Specs
    CaseCorsair 780T
    OS Windows 10 Pro
    Oct 2014
    33
    617
    Quote Originally Posted by Chino View Post
    Hey
    very well thank you chino and deon, ill just run the think full speed
    Max
    Case : Corsair 780T
